Hi!
I have following configuration:
NAS (192.168.1.118) → Apache → Nextcloud/DAV
ROUTER/Firewall/HAproxy (192.168.1.1)
Server (192.168.1.100) → Apache with severals vhost
I want to bring up one vhost as test with following configuration
<VirtualHost *:80>
ServerAdmin mail@joelmueller.ch
ServerName joelmueller.ch
ServerAlias www.joelmueller.ch
DocumentRoot /usr/share/webapps/blog/
DirectoryIndex index.php
RemoteIPProxyProtocol On
<Directory /usr/share/webapps/blog>
Options +Indexes +FollowSymLinks +MultiViews
AllowOverride All
Order allow,deny
allow from all
<FilesMatch \.php$>
# For Apache version 2.4.10 and above, use SetHandler to run PHP as a fastCGI process server
SetHandler "proxy:unix:/run/php-fpm/php-fpm.sock|fcgi://localhost"
</FilesMatch>
<Files "*.php">
MultiviewsMatch Any
</Files>
</Directory>
ErrorLog /var/log/httpd/blog_error.log
CustomLog /var/log/httpd/blog_access.log combined
</VirtualHost>
My HAproxy.conf file looks like this
cat haproxy.conf
uid 80
gid 80
chroot /var/haproxy
stats socket /var/run/haproxy.socket group proxy mode 775 level admin
nbproc 1
nbthread 4
hard-stop-after 60s
no strict-limits
maxconn 10000
spread-checks 2
tune.bufsize 16384
tune.lua.maxmem 0
log /var/run/log local0 info
lua-prepend-path /tmp/haproxy/lua/?.lua
option redispatch -1
maxconn 5000
timeout client 30s
timeout connect 30s
timeout server 30s
default-server init-addr last,libc
default-server maxconn 5000
# Frontend: O_SNI_fronted (Listening 0.0.0.0:80 0.0.0.0:443)
frontend O_SNI_fronted
bind 0.0.0.0:80 name 0.0.0.0:80
bind 0.0.0.0:443 name 0.0.0.0:443
default_backend SSL_backend
# tuning options
timeout client 30s
# logging options
# Frontend: 1_HTTP_frontend (Listening 127.0.0.1:80)
frontend 1_HTTP_frontend
bind 127.0.0.1:80 name 127.0.0.1:80 accept-proxy
# tuning options
timeout client 30s
# logging options
# ACL: NO_SSL_Rule
acl acl_620808a860e296.91534155 req.ssl_ver gt 0
# ACTION: HTTP_TO_HTTPS_RULE
http-request redirect scheme https code 301 if !acl_620808a860e296.91534155
# Frontend: 1_HTTPS_frontend (Listening 127.0.0.1:443)
frontend 1_HTTPS_frontend
http-response set-header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
bind 127.0.0.1:443 name 127.0.0.1:443 accept-proxy ssl curves secp384r1 no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256 ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 alpn h2,http/1.1 crt-list /tmp/haproxy/ssl/6208140971a7a3.08696099.certlist
# tuning options
timeout client 15m
# logging options
# ACTION: PUBLIC_MAP_RULE
# NOTE: actions with no ACLs/conditions will always match
use_backend %[req.hdr(host),lower,map_dom(/tmp/haproxy/mapfiles/620809e036a6d1.87483247.txt)]
# Backend: SSL_backend (SSL backend)
backend SSL_backend
# health checking is DISABLED
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
server SSL_Server 127.0.0.1 send-proxy-v2 check-send-proxy
# Backend: 5erver_backend (Server backend)
backend 5erver_backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server 5erver_Server_80 192.168.1.100:80
# ERROR: server data not found (0b989d9b-eb50-4dff-8a2f-6bc56245fd74)
# Backend: NAS_backend (NAS backend)
backend NAS_backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server nas_Server_80 192.168.1.118:80
# ERROR: server data not found (36c63574-bd94-43f7-836e-cd78c8edc6c0)
My map files looks like this
#public subdomains mapping
flood 5erver_backend
frank 5erver_backend
www 5erver_backend
torrent 5erver_backend
grafana 5erver_backend
nas 5erver_backend
kvm 5erver_backend
monitoring 5erver_backend
speedtest 5erver_backend
sync 5erver_backend
tracker 5erver_backend
cloud NAS_backend
dav NAS_backend
How I can fix this error?
