503 Unavailable in ssl mode
I am new to HAProxy (its my first attempt).
I am trying to set up HAProxy in front of Kibana (on client nodes) in Elasticsearch cluster. Set up works fine for http requests (http://my_public_IP/p04), but gives 503 Unvailable reponse when tried with https (https://my_public_IP/p04)
I am using self signed certificate as it is in testing phase.
My config file is as follows
log 127.0.0.1 local2 info
pidfile /var/run/haproxy.pid
maxconn 4000
crt-base /etc/haproxy/ssl
frontend http-in
default_backend p04
timeout connect 300s
timeout client 300s
timeout server 300s
frontend https-in
bind *:443 ssl crt /etc/ssl/haproxy/haproxy.pem no-sslv3
option httpclose
acl acl_kibana path_beg /p04
use_backend p04 if acl_kibana
backend p04
option httpchk GET /
reqrep ^([^\ :])\ /p04/(.) \1\ /\2
server api-es-cn-1 10.130.0.9:5601 check inter 1000 fastinter 500 rise 2 fall 1
server api-es-cn-2 10.130.0.18:5601 check inter 1000 fastinter 500 rise 2 fall 1 backup
timeout client 300s
timeout server 300s
timeout http-keep-alive 5m
timeout http-request 5s
timeout client 300s
timeout server 300s
timeout check 300s
stats hide-version
stats refresh 10s
I can see my certificate (.pem) in the following format
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
I am stuck and can’t figure out what’s missing!!
Thanks in advance for your help.
muj33b
