Trying to configure the new ACME client in HAProxy 3.2.1, but not getting haproxy.cfg to validate.
The relevant documentation is here: HAProxy version 3.2.1-2 - Configuration Manual and here is the announcement: Announcing HAProxy 3.2
With the HAProxy’s ACME client I’m trying to replace acme.sh via which I install certificates like bellow, so I get the private key as a file with .key extension:
./acme.sh --install-cert -d yourdomain.tld --ecc \
--fullchain-file /etc/haproxy/certs/yourdomain.tld.pem.ecdsa \
--key-file /etc/haproxy/certs/yourdomain.tld.pem.ecdsa.key
That way I obtain both ECC and RSA cert for the site to serve them in a so called dual cert way with HAProxy:
# ls -lha /etc/haproxy/certs/
drwxr-xr-x 3 1000 1000 4.0K Jun 15 11:29 .
drwxr-xr-x 4 root root 4.0K Jun 15 10:13 ..
-rw-r--r-- 1 1000 1000 4.4K Jun 14 10:34 yourdomain.tld.pem.ecdsa
-rw------- 1 1000 1000 288 Jun 14 10:34 yourdomain.tld.pem.ecdsa.key
-rw-r--r-- 1 1000 1000 7.2K Jun 14 10:31 yourdomain.tld.pem.rsa
-rw------- 1 1000 1000 3.2K Jun 14 10:31 yourdomain.tld.pem.rsa.key
Now I’d like to renew these two certs with HAProxy. Here’s what how I’ve tried to configure HAProxy to use it’s ACME client:
stats socket /var/run/haproxy.sock mode 660 expose-fd listeners level admin
expose-experimental-directives
httpclient.resolvers.prefer ipv4
acme le_rsa
directory https://acme-staging-v02.api.letsencrypt.org/directory
account-key /etc/haproxy/certs/letsencrypt.account.key
contact john.doe@example.com
challenge HTTP-01
keytype RSA
bits 4096
map virt@acme
acme le_ecdsa
challenge HTTP-01
keytype ECDSA
curves P-384
map virt@acme
crt-store cert_files
crt-base /etc/haproxy/certs/
key-base /etc/haproxy/certs/
load crt yourdomain.tld.pem.rsa key yourdomain.tld.pem.rsa.key alias site_rsa acme le_rsa domains yourdomain.tld,www.yourdomain.tld,new.yourdomain.tld,dev.yourdomain.tld,blog.yourdomain.tld
load crt yourdomain.tld.pem.ecdsa key yourdomain.tld.pem.ecdsa.key alias site_ecdsa acme le_ecdsa domains yourdomain.tld,www.yourdomain.tld,new.yourdomain.tld,dev.yourdomain.tld,blog.yourdomain.tld
frontend web-https
bind :80
bind :443 ssl alpn h2,http/1.1 npn h2,http/1.1
bind quic4@:443 ssl alpn h3
bind quic6@:443 ssl alpn h3
http-request return status 200 content-type text/plain lf-string "%[path,field(-1,/)].%[path,field(-1,/),map(virt@acme)]\n" if { path_beg '/.well-known/acme-challenge/' }
ssl-f-use crt "@cert_files/site_rsa" acme le_rsa
ssl-f-use crt "@cert_files/site_ecdsa" acme le_ecdsa
http-request redirect scheme https if !{ ssl_fc }
When I specify key options on load crt lines I get the configuration error:
# haproxy -c -V -f /etc/haproxy/haproxy.cfg
[NOTICE] (733) : haproxy version is 3.2.1-f4d1a4e
[NOTICE] (733) : path to executable is /usr/local/sbin/haproxy
[ALERT] (733) : config : '@cert_files/site_ecdsa' in crt-list '/etc/haproxy/haproxy.cfg' line 42, is already defined with incompatible parameters:
- different parameter 'key' : previously 'yourdomain.tld.pem.ecdsa.key' vs '(null)'
When I remove those key options I get a different configuration error:
[NOTICE] (728) : haproxy version is 3.2.1-f4d1a4e
[NOTICE] (728) : path to executable is /usr/local/sbin/haproxy
[ALERT] (728) : config : error processing line 0 in file '@web-https' : unable to load SSL private key into SSL Context '@cert_files/site_ecdsa': passed a null parameter.
Since the config isn’t valid it’s not possible to renew the cert manually:
# echo "acme renew @cert_files/site_ecdsa" | socat stdio /var/run/haproxy.sock
No ACME configuration defined for file '@cert_files/site_ecdsa'.
Can anybody see what is going wrong?
Thank you.
