When using nginx I can just use the 497 error code specific to nginx
497 HTTP Request Sent to HTTPS Port
and redirect to https with this rule:
error_page 497 https://$host:$server_port$request_uri;
When using haproxy the only solution so far is to use two ports e.g. port 80 and 443 but I only have one port (8443).
I tried the errorloc option but when a client tries to connect to the https port I get an ssl handshare error that can not be catched with the errorloc option.
Idealy I would use the following but that does not work:
frontend http-in
bind :8443 ssl crt /usr/local/etc/haproxy/ssl/fullchain.pem alpn h2,http/1.1
maxconn 50
default_backend backend-server
