Always using default_backend
Hi guys,
i am lost in what I thought would be an easy use case. I have an application not HA ready and try to bind it to a single node of my cluster using this configuration:
log 127.0.0.1 local0
maxconn 2000
timeout connect  5000
timeout client  10000
timeout server  10000
frontend www-http-vip10
bind 194.113.6.10:443 ssl crt /etc/haproxy/ssl/wc_bitmarck_org.pem ca-file /etc/haproxy/ssl/cert.cabundle verify optional
timeout client 1h
These are the conditions I need to
/Web Client/Share/
/?ShareToken=
Wir versuchen die konstante Bedingung fĂĽr Filesharing zu erfassen
acl want_app1 path_dir ./Web%20Client/Share/. fshare1-http-vip10
acl want_app2 url_reg -i .?Sharetoken=. fshare1-http-vip10
testing if backend available
acl app1_avail nbsrv(fshare1-http-vip10) ge 1
acl app2_avail nbsrv(fshare1-http-vip10) ge 1
try to use one host only
use_backend fshare1-http-vip10 if want_app1 app1_avail
use_backend fshare1-http-vip10 if want_app2 app2_avail
default_backend www-http-vip10
frontend ssh-proxy-vip10
bind 194.113.6.10:22
default_backend ssh-backend-vip10
timeout client 1h
timeout connect 30000
timeout server 30000
option httpchk GET /
server fshare1 10.41.229.15:40443 ssl check inter 60000 weight 20 verify none
balance source
timeout server 1h
server GP1-HTTPS 10.41.229.15:20443 ssl check inter 60000 weight 10 verify none
server GP2-HTTPS 10.41.229.15:40443 ssl check inter 60000 weight 20 verify none
server GP3-HTTPS 10.41.229.15:60443 ssl check inter 60000 weight 30 verify none
server GP4-HTTPS 10.41.229.16:20443 ssl check inter 60000 weight 10 verify none
server GP5-HTTPS 10.41.229.16:40443 ssl check inter 60000 weight 20 verify none
server GP6-HTTPS 10.41.229.16:60443 ssl check inter 60000 weight 30 verify none
timeout server 1h
stick-table type ip size 200k expire 30m
stick on src
default-server inter 1s
server GP1-SSH 10.41.229.15:20022 weight 30
server GP2-SSH 10.41.229.15:40022 weight 20
server GP3-SSH 10.41.229.15:60022 weight 10
server GP4-SSH 10.41.229.16:20022 weight 30
server GP5-SSH 10.41.229.16:40022 weight 20
server GP6-SSH 10.41.229.16:60022 weight 10
could anyone help and tell me what I am doing wrong? It is always using default backend
Whats the trailing fshare1-http-vip10 supposed to do? Remove it.
I think you made your configuration unnecessarily complex. Why would you need to content-switch based on backend availability? Does your default backend serve the filesharing app? If not, then this doesn’t make sense.
Thanks, you are so right… “fshare1-http-vip10” was bogus extra value.
in the backend fshare1-http-vip10 there will be different ports from different loadbalancers pointing to same backend server. So I want this test to be done but commented it out for the meantime
I changed to:
Example for Expressions
https://myurl.com/Web%20Client/Share/OutgoingWizard.htm
https://myurl.com/?ShareToken=2A4AD21A59EF0CF9DA150999E4FAD5DA1E82B335
Regex to get above
#acl want_app1 url_reg ./Web\ Client/Share/.
acl want_app1 url_reg -i ./Web%20Client/Share/.
acl want_app2 url_reg -i .?ShareToken=.
Wir prĂĽfen ob das Backend da ist
#acl app1_avail nbsrv(fshare1-http-vip10) ge 1
#acl app2_avail nbsrv(fshare1-http-vip10) ge 1
Wir setzen den Server auf dx804
#use_backend fshare1-http-vip10 if want_app1 app1_avail
#use_backend fshare1-http-vip10 if want_app2 app2_avail
any more ideas? Results still in Backend: www-http-vip10
Could somebody please take a look? I am using CentOS haproxy is Version 1.5.
It is so weired. I tried different ways to catch the URL
#acl want_app1 url_reg .*\/Web\ Client\/Share\/.*
acl want_app1 path_reg .*\/Web%20Client\/Share\/.*
acl want_app2 path_reg .*\?ShareToken=.*
# Wir prĂĽfen ob das Backend da ist
# Wir setzen den Server auf dx804
use_backend fshare1-http-vip10 if { path_reg .*\/Web\ Client\/Share\/.* }
use_backend fshare1-http-vip10 if { path_reg .*\?ShareToken=.* }
Syntax is always fine but in logfile its always
Jul 10 13:14:29 localhost haproxy[29776]: Connect from 217.89.44.130:35289 to 194.113.6.10:443 (www-http-vip10/HTTP)
Ok, punch me if you see me or in other words… raising debuglevel proofed anything doing as expected since leasson I. Next question am I ready for vacation… Indeed! Sorry wasting your Time!
