Hi there, how would this Apache rewrite rule translate to HAProxy?
RewriteCond "%{QUERY_STRING}" !hint
RewriteRule "endpoint/o/authz" "/endpoint/o/authz?hint=xyz" [QSA,PT]
I tried the following, but it does not seem to work.
acl is_not_hint path_reg !-m /endpoint/o/authz?hint
http-request replace-path /endpoint/o/authz?(.*) /endpoint/o/authz?hint=xyz\1 if is_not_hint
Any insigth will be appreceiated. Thanks!
