Hello all,
I am stress testing my HAProxy setup and i noticed that my backend IP is exposed! When i make same test to my nginx proxy the IP addresses is not shown to my stress tool. Is it by design or its my configuration mistake ?
I am proxying my another nginx installation with HAProxy.
echo “GET http://Frontend IP:8088/app_api.php” | vegeta -cpus=4 attack -connections=1000000 -timeout=2m -rate=30000 -workers=50 | tee results.bin | vegeta report
^CRequests [total, rate] 14470, 3902.70
Duration [total, attack, wait] 4.036639963s, 3.707685559s, 328.954404ms
Latencies [mean, 50, 95, 99, max] 20.845444ms, 0s, 0s, 272.588244ms, 4.021258059s
Bytes In [total, mean] 15390, 1.06
Bytes Out [total, mean] 0, 0.00
Success [ratio] 0.00%
Status Codes [code:count] 0:14350 404:30 429:90
Error Set:
Get http://Frontend IP:8088/app_api.php: dial tcp: lookup p1.dtv.sx on 127.0.0.53:53: no such host
Get http://Frontend IP:8088/app_api.php: dial tcp: lookup p1.dtv.sx on 127.0.0.53:53: dial udp 127.0.0.53:53: socket: too many open files
404 Not Found
429 Too Many Requests
Get http://Frontend IP:8088/app_api.php: dial tcp 0.0.0.0:0->Backend IP:8088:8000: socket: too many open files
Get http://Frontend IP:8088/app_api.php: dial tcp 0.0.0.0:0->Backend IP:8088:8000: connect: connection refused
HAProxy Configuration;
nbproc 1
nbthread 4
cpu-map auto:1/1-4 0-3
maxconn 1000000
#option forwardfor
option http-buffer-request
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 300000
backend per_ip_rates
stick-table type ip size 1m expire 10m store http_req_rate(10s)
frontend fe1
bind :8088
http-request track-sc0 src table per_ip_rates
http-request deny deny_status 429 if { sc_http_req_rate(0) gt 100 }
reqidel ^X-Forwarded-For:.*
default_backend backend_servers
option httpchk
server domain1 backendIP check port 80
bind :19090
stats hide-version
stats refresh 10s
stats show-legends
stats show-node
stats auth
stats uri /
HAProxy -vv ;
HA-Proxy version 1.9.6-1ppa1~bionic 2019/03/30 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-YXfmbO/haproxy-1.9.6=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Built with PCRE2 version : 10.31 2018-02-12
h2 : mode=HTX side=FE|BE
h2 : mode=HTTP side=FE
: mode=TCP|HTTP side=FE|BE
Thanks!
Talion
