I am looking at forwarding HTTP (front end) to HTTPS (backend). Backend is not being invoked.
Simplified to only HTTP to HTTP, still no luck.
HA-Proxy version 1.8.7 2018/04/07
Debug mode shows only this
haproxy -f /etc/haproxy/haproxy.cfg -d
Using epoll() as the polling mechanism.
00000000:http-in.accept(0004)=0006 from [127.0.0.1:59088] ALPN=
00000000:http-in.clicls[adfd:ffffffff]
00000000:http-in.closed[adfd:ffffffff]
Configuration
log 127.0.0.1 local6
#daemon
maxconn 256
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend http-in
#log 127.0.0.1 local6
bind *:8091
use_backend dcc
backend dcc
server localhost :9022
