Best Configuration for live audio streaming
Discovered HAProxy about a month ago and I LOVE it. I built my own streaming CDN on Ubuntu and things are working well. In an effort to optimize my configuration, I was hoping to pick the brains of all of you on the best way to handle streaming connections with HAProxy.
I’m running v1.6.5 on Ubuntu 14.04 64 bit and all is well, just want to make sure I’m using best practices.
Here is my config:
    ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:EC$
maxconn 50000
timeout connect 10000
frontend LHR_Load_Balancer
bind *:8000
stats uri /haproxy?stats
stats auth UID:PASSWORD
default_backend ICY_Cluster
backend ICY_Cluster
server s1 FQDN:8000 weight 40 check
server s2 FQDN:8000 weight 40 check
server s3 FQDN:8000 weight 20 check
Thank you in advance for your feedback.
