Config Critique for Exchange 2010
Hi all, new to haproxy and I’m trying to setup a box to proxy traffic from the internet to our internal Exchange server.
Ideally we simply want to check the FQDN being used in the request is valid, check the path is valid for Exchange services, and decrypt, check, and pass “clean” requests to the backend server using SSL.
Any other requests should just bump to our corporate website.
Are there any glaring issues with the config below please? It appears to work but at our small size it’s tricky to test with a real-world load.
    log /dev/log    local0
    log /dev/log    local1 notice
    maxconn 5000
    log     global
    maxconn 5000
    mode    http
    option  httplog
    option  dontlognull
    timeout client  50000
    timeout server  50000
listen stats x.x.x.x:4711
    stats hide-version
    stats uri /
frontend webmail_frontend
    bind x.x.x.x:443 ssl crt /etc/ssl/certs/webmail.pem
    acl webmail_paths path_beg -i /autodiscover/ /ecp/ /ews/ /exchange/ /exchweb/ /microsoft-server-activesync/ /oab/ /owa/ /public/ /rpc/ /rpcwithcert/
    acl webmail_hosts hdr_dom(Host) -i a.b.c.d
    use_backend webmail_backend if webmail_paths webmail_hosts
    default_backend webmail_redirect
    option ssl-hello-chk
    option tcp-check
    stick-table type ip size 20k expire 15m
    stick on src
    timeout server 10m
    server webmail a.b.c.d x.x.x.x:443 ssl verify none weight 1 check port 443 inter 5000 rise 2 fall 3
    redirect location http://www.corp
