Howdy,
I’m trying to condense my configruation for 1.6.6 a bit. Instead of
frontend FE-1
bind 172.17.1.11:443 ssl crt /etc/ssl/private/mycert.pem
reqadd "X-Forwarded-Proto: https"
default_backend app-servers
frontend FE-2
bind 172.17.1.12:443 ssl crt /etc/ssl/private/mycert.pem
frontend FE-3
bind 172.17.1.13:443 ssl crt /etc/ssl/private/mycert.pem
I thought I could do something like
frontend SSL
bind 172.17.1.11:443 ssl crt /etc/ssl/private/mycert.pem name FE-1
bind 172.17.1.12:443 ssl crt /etc/ssl/private/mycert.pem name FE-2
bind 172.17.1.13:443 ssl crt /etc/ssl/private/mycert.pem name FE-3
The docs tell me
name
Sets an optional name for these sockets, which will be reported on the stats
page.
However, I seem not the see any of may names on the stats page.
Is it a misunderstanding on my side what the name is for, or may it be a bug?
Sascha
