Blocking single TLS SNI
Hello HAProxy community,
I have HAProxy acting as Load Balancer to a Kubernetes Cluster. I have a wildcard DNS entry for my “public” IP address on the HAProxy. I also have a wild card TLS Certificate.
When I deploy a new application on Kubernetes it appears as new_application.mykyubdomain.com. Internally I access this no problem. This is combination of wild card DNS, TLS SNI and HAProxy magic working.
I would like to block a single application (TLS SNI) on the HAProxy. So my understanding is I need to inspect the SNI to see which application (TLS SNI) I am looking at and block it using tcp-request content reject.
This a snippet from the frontend section of my HAProxy settings for Kubernetes Cluster.
acl stop_app_ssl req_ssl_sni new_application1.mykyubdomain.com
tcp-request content reject if stop_app_ssl
This is all in mode tcp as it is TLS traffic. The TLS termination is on the Kubernetes Cluster. I am not off loading the encryption to the HAProxy.
I have set-up Wireshark and can the SNI “new_application1.mykyubdomain.com” in TLS extension SNI when I connect to new_application1 but HAProxy does not block the traffic.
I have the following version of HAProxy running on rhel 7.
What am I doing wrong? Any advice much appreciated. If I have not made anything clear please ask.
[root@rhoslb1 haproxy]# haproxy -vv
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Best Regards,
Kevin.
Share the entire configuration please.
Global settings
maxconn 20000
log /dev/log local0 info
pidfile /var/run/haproxy.pid
# turn on stats unix socket
#Global settings
maxconn 20000
#common defaults that all the ‘listen’ and ‘backend’ sections will
#use if not designated in their block
timeout http-request 10s
timeout queue 1m
timeout client 300s
timeout server 300s
timeout http-keep-alive 10s
timeout check 10s
maxconn 20000
bind :9000
stats uri /
frontend atomic-openshift-api
bind 10.2.134.171:443
default_backend atomic-openshift-api
balance source
server master1.mydomain.com rhosmaster1.mydomain.com:443 check
server master2.mydomain.com rhosmaster2.mydomain.com:443 check
server master3.mydomain.com rhosmaster3.mydomain.com:443 check
frontend infrarouter
bind 10.2.134.172:80
default_backend infrarouter
# below is ACL to block by hostname
#acl restricted_page hdr(host) -i bird-test-kevintest.apps.mydomain.com
# ACL for specific IP addresses
#acl restrited_source_ip src 10.2.8.152
#acl restrited_source_ip_gs src 10.2.8.162
#http denty request based on the ACLs
#http-request deny if restricted_page restrited_source_ip_gs
backend infrarouter
balance source
server infra1.mydomain.com rhosinfra1.mydomain.com:80 check
server infra2.mydomain.com rhosinfra2.mydomain.com:80 check
server infra3.mydomain.com rhosinfra3.mydomain.com:80 check
frontend infrarouter-secure
bind 10.2.134.172:443
default_backend infrarouter-secure
acl stop_app_ssl req_ssl_sni django-ex-kevintest.apps.mydomain.com
balance source
server infra1.mydomain.com rhosinfra1.mydomain.com:443 check
server infra2.mydomain.com rhosinfra2.mydomain.com:443 check
server infra3.mydomain.com rhosinfra3.mydomain.com:443 check
"# use if not designated in their block
timeout queue 1m
timeout client 300s
timeout server 300s
timeout check 10s
maxconn 20000
bind :9000
stats uri /
balance source
#below is ACL to block by hostname
#ACL for specific IP addresses
# http denty request based on the ACLs
backend infrarouter
balance source
balance source
We must not accept the the content earlier.
Try something like this:
tcp-request content reject if { req_ssl_hello_type 1 stop_app_ssl }
tcp-request content accept if { req_ssl_hello_type 1 ! stop_app_ssl }
Thanks for quick response!
That does not work unfortunately. It complains when I put the configuration in place. I think this is just a syntax issue?
Below is error.
root@rhoslb1 haproxy]# haproxy -f /etc/haproxy/haproxy.cfg -d
[ALERT] 224/092416 (67628) : parsing [/etc/haproxy/haproxy.cfg:117] : ‘tcp-request content reject’ : error detected in frontend ‘infrarouter-secure’ while parsing ‘if’ condition : ‘stop_app_ssl’ is not a number
[ALERT] 224/092416 (67628) : parsing [/etc/haproxy/haproxy.cfg:118] : ‘tcp-request content accept’ : error detected in frontend ‘infrarouter-secure’ while parsing ‘if’ condition : ‘!’ is not a number
[ALERT] 224/092416 (67628) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT] 224/092416 (67628) : Fatal errors found in configuration.
Like I say I think syntax problem with the and for the tcp-request content accept / reject rules.
I have tried the following
acl stop_app_ssl req_ssl_sni django-ex-kevintest.mydomain.com
tcp-request content reject if { req_ssl_hello_type 1 } stop_app_ssl
tcp-request content accept if { req_ssl_hello_type 1 } ! stop_app_ssl
The configuration starts with no errors but the application (site django-ex-kevintest) is still accessible. I want to block it.
I am checking out what the correct syntax and in tcp-request content is?
Kevin.
I restarted the haproxy with the new entry below and it works.
acl stop_app_ssl req_ssl_sni django-ex-kevintest.apps.rhos.agriculture.gov.ie
tcp-request content accept if { req_ssl_hello_type 1 } !stop_app_ssl
Thanks so much for solution Lukastribus.
You Rock!!!
