Hi Lukas,
Can you confirm you are reloading haproxy via systemd, by issuing systemctl reload haproxy ?
yes, this is correct.
the output of haproxy -vv
this is the current installation i wanted to use (3.0 LTS):
root@haproxy-02:/home/localadm# haproxy -vv
HAProxy version 3.0.11-1~bpo12+1 2025/06/03 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2029.
Known bugs: http://www.haproxy.org/bugs/bugs-3.0.11.html
Running on: Linux 6.1.0-38-cloud-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.147-1 (2025-08-02) x86_64
TARGET = linux-glibc
CC = x86_64-linux-gnu-gcc
CFLAGS = -O2 -g -fwrapv -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_OT=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_QUIC_OPENSSL_COMPAT=1
DEBUG =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC -OPENSSL_WOLFSSL +OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION +QUIC +QUIC_OPENSSL_COMPAT +RT +SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=2).
Built with OpenSSL version : OpenSSL 3.0.15 3 Sep 2024
Running on OpenSSL version : OpenSSL 3.0.17 1 Jul 2025 (VERSIONS DIFFER!)
Built with Lua version : Lua 5.4.4
Built with OpenTracing support.
Built with PCRE2 version : 10.42 2022-12-11
Built with gcc compiler version 12.2.0
quic : mode=HTTP side=FE mux=QUIC flags=HTX|NO_UPG|FRAMED
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
[ OT] opentracing
but i also have one node with 3.2 LTS to check if the issue is gone with the latest version. I saw that 3.2 this is the latest LTS release:
root@haproxy-01:/home/localadm# haproxy -vv
HAProxy version 3.2.5-1~bpo12+1 2025/09/26 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2030.
Known bugs: http://www.haproxy.org/bugs/bugs-3.2.5.html
OPTIONS = USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_OT=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1 USE_QUIC_OPENSSL_COMPAT=1
DEBUG =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC -OPENSSL_WOLFSSL +OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION +QUIC +QUIC_OPENSSL_COMPAT +RT +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB +ACME
Built with multi-threading support (MAX_TGROUPS=32, MAX_THREADS=1024, default=2).
Built with SSL library version : OpenSSL 3.0.17 1 Jul 2025
Running on SSL library version : OpenSSL 3.0.17 1 Jul 2025
QUIC: connection socket-owner mode support : yes
QUIC: GSO emission support : yes
<default> : mode=SPOP side=BE mux=SPOP flags=HOL_RISK|NO_UPG
spop : mode=SPOP side=BE mux=SPOP flags=HOL_RISK|NO_UPG
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
[ OT] opentracing
the output of systemctl status haproxy
root@haproxy-01:/home/localadm# systemctl status haproxy
Loaded: loaded (/lib/systemd/system/haproxy.service; enabled; preset: enabled)
Active: active (running) since Mon 2025-09-29 13:32:02 UTC; 1 week 0 days ago
Docs: man:haproxy(1)
Process: 3758559 ExecReload=/usr/sbin/haproxy -Ws -f $CONFIG -c $EXTRAOPTS (code=exited, status=0/SUCCESS)
Process: 3758561 ExecReload=/bin/kill -USR2 $MAINPID (code=exited, status=0/SUCCESS)
Main PID: 3148053 (haproxy)
Status: "Ready."
Tasks: 3 (limit: 4685)
Memory: 80.3M
CPU: 3min 43.709s
├─3148053 /usr/sbin/haproxy -sf 3148144 -x sockpair@4 -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.p>
└─3758563 /usr/sbin/haproxy -sf 3148144 -x sockpair@4 -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.p>
Oct 07 09:04:24 haproxy-01 haproxy[3758563]: haproxy-01 haproxy[3758563]: 168.63.129.16:60502 [07/Oct/2025:09:04:09.>
Oct 07 09:04:39 haproxy-01 haproxy[3758563]: haproxy-01 haproxy[3758563]: 168.63.129.16:61056 [07/Oct/2025:09:04:24.>
Oct 07 09:04:54 haproxy-01 haproxy[3758563]: haproxy-01 haproxy[3758563]: 168.63.129.16:61570 [07/Oct/2025:09:04:39.>
Oct 07 09:05:09 haproxy-01 haproxy[3758563]: haproxy-01 haproxy[3758563]: 168.63.129.16:62236 [07/Oct/2025:09:04:54.>
Oct 07 09:05:24 haproxy-01 haproxy[3758563]: haproxy-01 haproxy[3758563]: 168.63.129.16:62819 [07/Oct/2025:09:05:09.>
a full cat of the systemd unit file as shown in the previous commands (or all files if multiple are referred to)
Do you mean this file?
root@haproxy-01:/home/localadm# cat /lib/systemd/system/haproxy.service
[Unit]
Documentation=man:haproxy(1)
Documentation=file:/usr/share/doc/haproxy/configuration.txt.gz
After=network-online.target rsyslog.service
Wants=network-online.target
[Service]
EnvironmentFile=-/etc/default/haproxy
EnvironmentFile=-/etc/sysconfig/haproxy
BindReadOnlyPaths=/dev/log:/var/lib/haproxy/dev/log
Environment="CONFIG=/etc/haproxy/haproxy.cfg" "PIDFILE=/run/haproxy.pid" "EXTRAOPTS=-S /run/haproxy-master.sock"
ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS
KillMode=mixed
Restart=always
SuccessExitStatus=143
Type=notify
# The following lines leverage SystemD's sandboxing options to provide
# defense in depth protection at the expense of restricting some flexibility
# in your setup (e.g. placement of your configuration files) or possibly
# reduced performance. See systemd.service(5) and systemd.exec(5) for further
# information.
# NoNewPrivileges=true
# ProtectHome=true
# If you want to use 'ProtectSystem=strict' you should whitelist the PIDFILE,
# any state files and any other files written using 'ReadWritePaths' or
# 'RuntimeDirectory'.
# ProtectSystem=true
# ProtectKernelTunables=true
# ProtectKernelModules=true
# ProtectControlGroups=true
# If your SystemD version supports them, you can add: @reboot, @swap, @sync
# SystemCallFilter=~@cpu-emulation @keyring @module @obsolete @raw-io
[Install]
WantedBy=multi-user.target
information about how haproxy was installed and upgraded on this machine (whether it was installed from source or with a package manager)
I installed and upgraded HAProxy via ansible. For the upgrade to 3.2 i just changed the repo to add and the version to install.
- name: Install HAProxy 3.0-stable (LTS)
block:
- name: Add repo using key from URL
ansible.builtin.deb822_repository:
types: deb
uris: http://haproxy.debian.net
suites: bookworm-backports-3.0
components: main
architectures: amd64
signed_by: https://haproxy.debian.net/bernat.debian.org.gpg
- name: Apt update
ansible.builtin.apt:
update_cache: true
force_apt_get: true
cache_valid_time: 3600
- name: Install HAProxy 3.0.x
state: present
