Can't get HAPROXY to send stats or info data to Metricbeat
- module: haproxy
  metricsets: ["info", "stat"]
  period: 10s
  hosts: ["tcp://[unique_host]:14567"]
  username : "haproxy"
  password : "haproxy"
  enabled: true
    log         127.0.0.1 local0
    chroot      /var/lib/haproxy
    # STIG'd to V-240092
    maxconn     32768
    user        haproxy
    group       haproxy
    stats socket 127.0.0.1:14567 user haproxy group haproxy mode 660 level admin
    # turn on stats unix socket
    #stats socket /var/lib/haproxy/stats
    # STIG'd to V-240058
    stats socket /var/run/haproxy.sock user haproxy group haproxy mode 600 level admin
    ssl-default-server-ciphers PROFILE=SYSTEM
    mode                    tcp
    stats auth haproxy:haproxy
    retries                 3
    # STIG'd to V-240039
    timeout http-request    5000s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout client-fin      30s
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
# Stats Listener
   bind 0.0.0.0:14567
   stats uri /stats
Above are the haproxy yml for metricbeat and the haproxy.cfg.
While metricbeats is running, HAProxy gives these logs:
000000c1:stats.accept(000b)=0012 from [[IP]:35990] ALPN=
000000c1:stats.clicls[adfd:ffffffff]
000000c1:stats.closed[adfd:ffffffff]
000000c2:stats.accept(000b)=0013 from [[IP]:39830] ALPN=
000000c3:stats.accept(000b)=0012 from [[IP]:39828] ALPN=
000000c3:stats.clicls[adfd:ffffffff]
000000c2:stats.clicls[adfd:ffffffff]
000000c3:stats.closed[adfd:ffffffff]
000000c2:stats.closed[adfd:ffffffff]
000000c4:stats.accept(000b)=0012 from [[IP]:39834] ALPN=
000000c5:stats.accept(000b)=0013 from [[IP]:39836] ALPN=
000000c4:stats.clicls[adfd:ffffffff]
000000c5:stats.clicls[adfd:ffffffff]
000000c5:stats.closed[adfd:ffffffff]
000000c4:stats.closed[adfd:ffffffff]
So HAProxy is obviously getting hit by Metricbeat.
But on Metricbeat side I get this:
{“log.level”:“error”,“@timestamp”:“2024-04-08T19:35:59.000Z”,“log.origin”:{“function”:“github.com/elastic/beats/v7/metricbeat/mb/module.(*metricSetWrapper).fetch",“file.name”:“module/wrapper.go”,“file.line”:256},“message”:"Error fetching data for metricset haproxy.info: failed fetching haproxy info: got empty response from HAProxy”,“service.name”:“metricbeat”,“ecs.version”:“1.6.0”}
{“log.level”:“error”,“@timestamp”:“2024-04-08T19:35:59.000Z”,“log.origin”:{“function”:“github.com/elastic/beats/v7/metricbeat/mb/module.(*metricSetWrapper).fetch",“file.name”:“module/wrapper.go”,“file.line”:256},“message”:"Error fetching data for metricset haproxy.stat: failed fetching haproxy stat: got empty response from HAProxy”,“service.name”:“metricbeat”,“ecs.version”:“1.6.0”}
{“log.level”:“error”,“@timestamp”:“2024-04-08T19:36:09.103Z”,“log.origin”:{“function”:“github.com/elastic/beats/v7/metricbeat/mb/module.(*metricSetWrapper).fetch",“file.name”:“module/wrapper.go”,“file.line”:256},“message”:"Error fetching data for metricset haproxy.info: failed fetching haproxy info: got empty response from HAProxy”,“service.name”:“metricbeat”,“ecs.version”:“1.6.0”}
{“log.level”:“error”,“@timestamp”:“2024-04-08T19:36:09.103Z”,“log.origin”:{“function”:“github.com/elastic/beats/v7/metricbeat/mb/module.(*metricSetWrapper).fetch",“file.name”:“module/wrapper.go”,“file.line”:256},“message”:"Error fetching data for metricset haproxy.stat: failed fetching haproxy stat: got empty response from HAProxy”,“service.name”:“metricbeat”,“ecs.version”:“1.6.0”}
When it hits HAProxy for stats and info, there’s an empty response.
Any suggestions?
