Custom 503 error files not loaded
I have problems with a new plain config to get custom error pages working. E.g. for 503 error I want to use the error file 503-alt.http but it doesn’t seem to be loaded in haproxy.cfg. It still uses the default 503 error file. Permissions on the 503-alt.http are set correctly.
When I paste the contents of my custom error file into the default 503 error file, the error page is displayed correctly.
Here’s the current haproxy.cfg. Do I have any configuration errors in my config files?
        log /dev/log    local0
        log /dev/log    local1 notice
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
http-errors pm_default_maintenance
        errorfile 503 /etc/haproxy/errors/503-alt.http
frontend stats
    bind *:8404
    stats uri /stats
    stats refresh 10s
    stats admin if LOCALHOST
frontend http_frontend
    acl maintenance_mode nbsrv(testsrv) eq 0
    use_backend maintenance if maintenance_mode
    default_backend testsrv
#frontend https-frontend
#    mode http
#    acl maintenance_mode testsrv eq 0
#    use_backend maintenance if maintenance_mode
#    bind *:443 ssl crt-list /etc/pki/tls/certs/crt-list.txt
#    default_backend testsrv
backend maintenance
    errorfiles pm_default_maintenance
    http-response return  status 503  default-errorfiles  if { status 503 }
backend testsrv
    server srv1 mac.domain.local:80
Thanks,
jpm
