Deny requests if URI ends with "/$" (regex) solved
Hello all,
i tried to deny requests if regexp matches the uri and ends just with a “/”. Unfortunately it does not work. The setup is HAproxy in OPNsense.
regexp looks like: .*.example.com/$
If there is no path there is nothing to match.
http://www.example.org
is exactly the same as
http://www.example.org/
it just sometimes displayed differently in the browser. The request line in both cases looks like:
GET / HTTP/1.1
Hi lukastribus,
your answer pointed me to the solution.
Now i have this regex: ^/$
In my case this fits, because every data which should be delivered has a filename with extension.
Thanks again!
