I’ve got HAProxy running as a forwarding SSH proxy:
resolvers internal
hold nx 30s
hold obsolete 30s
hold other 30s
hold refused 30s
hold timeout 30s
hold valid 30ss
timeout resolve 1s
timeout retry 1s
accepted_payload_size 8192
resolve_retries 3
parse-resolv-conf
frontend fe_ssh from unnamed_defaults_1
bind *:22 ssl crt /etc/haproxy/ssl/mu-ssh.crt
acl valid_payload req.payload(0,7) -m str "SSH-2.0"
log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq dstName:%[var(sess.dstName)] dstIP:%[var(sess.dstIP)] "
timeout client 15m
tcp-request content do-resolve(sess.dstIP,internal,ipv4) ssl_fc_sni
tcp-request content set-var(sess.dstName) ssl_fc_sni
default_backend ssh-all
backend ssh-all from unnamed_defaults_1
tcp-request content set-dst var(sess.dstIP)
acl allowed_destinations var(sess.dstName) -m sub .mu.svc.cluster.local
tcp-request content accept if allowed_destinations
tcp-request content reject
server ssh 0.0.0.0:22
I’m attempting to connect to a backend both using ssh and a script in GoLang.
With SSH, this works: ssh -o ProxyCommand="openssl s_client -quiet -connect haproxy:22 -servername int.mu.svc.cluster.local 2>/dev/null", however in Go, where I’m establishing a TLS connection first, then an SSH connection atop that, it fails.
The logs indicate that the SNI resolution isn’t happy; in the successful scenario:
fe_ssh~ ssh-all/ssh 220/0/434 2769 -- 1/1/0/0/0 0/0 dstName:int.mu.svc.cluster.local dstIP:10.152.183.251
Whereas in my script, HAProxy logs:
fe_ssh~ ssh-all/<NOSRV> -1/-1/14 0 CR 1/1/0/0/0 0/0 dstName:int.mu.svc.cluster.local dstIP:-
For some reason, even though the dstName is the same, dstIP isn’t being correctly resolved, and thus the connection is failing.
Any ideas?
