Hey! I’m trying to update a legacy setup where the team I am on inherited multiple rev-proxies and I’m trying to combine them into one. The issue I am having is even when I get a successful config to startup the haproxy service I can’t get it to work 100% of the time. It looks like it’s not following any of the rules and just defaulting to the default backend. We are now testing w/o a default backend and just trying to route on the incoming request url. The connections are coming from a metabase server using JDBC connection strings, and I’m thinking that maybe the SNI is not coming over correctly since it’s behind a load balancer in the cloud. I can’t configure the logs to even show anything helpful. Here is the config that we are using…
> global
> log 127.0.0.1 local2
> chroot /var/lib/haproxy
> pidfile /var/run/haproxy.pid
> user haproxy
> group haproxy
> daemon
> defaults
> mode tcp
> option tcplog
> log global
> timeout queue 5m
> timeout connect 10s
> timeout client 5m
> timeout server 5m
> maxconn 3000
> # see /etc/resolv.conf nameserver address
> resolvers corpdns
> nameserver resolver 10.10.0.2:53
> frontend health_check
> bind *:80
> mode http
> monitor-uri /health_check
> frontend https
> bind *:443
> mode tcp
> tcp-request inspect-delay 5s
> tcp-request content capture req.ssl_sni len 25
> tcp-request content accept if { req_ssl_hello_type 1 }
> use_backend dbread_uat if { req.ssl_sni -i db-read-new.uat.fakeurl.com }
> use_backend dbread_preprod if { req.ssl_sni -i db-read.preprod.fakeurl.com }
> backend dbread_uat
> mode tcp
> server replica_uat db-replica.uat.fakeurl.com:5432 check resolvers corpdns
> mode tcp
> server replica_preprod db-replica.preprod.fakeurl.com:5432 check resolvers corpdns
