Do-resolve not working
Hello everyone,
I have an issue where I configured resolvers and have this line in my configuration:
tcp-request content do-resolve(sess.dstIP,mydns,ipv4) ssl_fc_sni
and it doesn’t work, in the logs the variable sess.dstIP shows as -
And I also added printing of the ssl_fc_sni in the logs to check its value and its the expected domain.
Configuration:
resolvers mydns
    accepted_payload_size 8192
    nameserver dns1 10.116.30.30:53
    resolve_retries      3
    timeout resolve      10s
    timeout retry        10s
    hold other           30s
    hold refused         30s
    hold nx              30s
    hold timeout         30s
    hold valid           10s
    hold obsolete        30s
frontend ssh_frontend
   bind *:2222 ssl crt /etc/haproxy/certs/ssl.pem
   log-format "%ci:%cp [%t] SNI:%[ssl_fc_sni] dstName:%[var(sess.dstName)] dstIP:%[var(sess.dstIP)] "
   tcp-request content set-var(sess.dstName) ssl_fc_sni
   default_backend ssh-all
backend ssh-all
   tcp-request content set-dst var(sess.dstIP)
   server ssh 0.0.0.0:22
The log outputs lines like:
SNI:master-1 dstName:master-1 dstIP:-
I tested this by following the official documentation on how to setup ssh proxy-ing using DNS:
using dig on the haproxy machine returns the expected A record:
dig A @10.116.30.30 -p 53 master-1 +short
10.119.29.100
tcpdump doesn’t show any packets going towards or from 10.116.30.30 host so no DNS query attempt was even made.
haproxy -vv
# haproxy -vv
HA-Proxy version 2.2.13-5f3eb59 2021/04/02 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.13.html
Running on: Linux 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
  OPTIONS = USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1
  DEBUG   =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Built without PCRE or PCRE2 support (using libc's regex instead)
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-44)
            fcgi : mode=HTTP       side=BE        mux=FCGI
       <default> : mode=HTTP       side=FE|BE     mux=H1
              h2 : mode=HTTP       side=FE|BE     mux=H2
       <default> : mode=TCP        side=FE|BE     mux=PASS
Available services : none
	[FCGI] fcgi-app
uname -a
# uname -a
Linux linux 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
I ran into something kind of similar. On examing some tcpdumps, I discovered that haproxy was sending malformed DNS query requests. It looked like a possible buffer oveflow, because there was additional data after the domain (in my case part of another HTTP header). I was able to work around it by storing the domain I wanted in a temporary variable and then use that variable instead of the fetch directly.
However, in my case I was using a converter on the fetch. I’m not sure if that made a difference. It was also happening on ubuntu 16.04, but I wasn’t able to reproduce on 20.04. I’m not sure why.
I’m also not sure if that is the same issue that you are seeing.
Try adding a tcp-request inspect-delay before the do-resolve.
I think you will need tcp-request inspect-delay 5s in the frontend config and you should define some acls in the backend.
But to be honest - I would leave the DNS nonsense and set the servers over backend config - for security reasons.
