I configured the haproxy with more than 50 domains, and everything works fine, only this subdomain takes the cookies from different frontend ( sometimes takes from the right cookies) and I cannot find the solution for this subject, any ideas to solve this matter? here’s the configuration and i attach the cookie that he use instead the cookie he should have use
log 127.0.0.1:514 local0
maxconn 1000000
ulimit-n 60000
ssl-default-bind-options ssl-min-ver TLSv1.2
option log-separate-errors
log-format %[capture.req.hdr(0)]:%cp\ [%t]\ %f\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ {%hrl}\ {%hsl}\ %{+Q}r
timeout connect 3m
timeout client 10m
timeout server 10m
option httpchk
frontend admweb
capture request header X-Forwarded-For len 15
default_backend admweb_backendnodes
timeout client 1m
timeout http-request 1m
acl adamtotal hdr(host) -m reg -i DOMAIN.co.il
use_backend DOMAIN.co.il_backendnodes if adamtotal
acl technion.adamtotal hdr(host) -m reg -i SUB.DOMAIN.co.il
use_backend SUB.DOMAIN.co.il_backendnodes if technion.adamtotal
frontend admweb_SSL
bind *:443 ssl crt-list /etc/ssl/private/crt-list.txt
default_backend admweb_backendnodes_SSL
acl adamtotal_ssl hdr(host) -m reg -i DOMAIN.co.il
use_backend DOMAIN.co.il_backendnodes_SSL if adamtotal_ssl
acl technion.adamtotal_ssl hdr(host) -m reg -i SUB.DOMAIN.co.il
use_backend SUB.DOMAIN.co.il_backendnodes_SSL if technion.adamtotal_ssl
cookie SERVERUSED insert indirect nocache
option log-health-checks
http-check connect port 443 ssl sni DOMAIN.co.il
http-check send meth GET uri /lbmanager.aspx ver HTTP/1.1 hdr host DOMAIN.co.il
http-check expect status 200
default-server inter 3s fall 3 rise 2
server 10.168.168.20 10.168.168.20:443 maxconn 10000 check ssl verify none cookie adamt1
server 10.168.168.89 10.168.168.89:443 maxconn 10000 check ssl verify none cookie adamt2
server 10.168.168.35 10.168.168.35:443 maxconn 10000 check ssl verify none cookie adamt3
server 10.168.168.52 10.168.168.52:443 maxconn 10000 check ssl verify none cookie adamt5
server 10.168.168.40 10.168.168.40:443 maxconn 10000 check ssl verify none cookie adamt4
http-check connect
http-check expect rstatus (2|3)[0-9][0-9]
server 10.168.168.20 10.168.168.20:80 maxconn 10000 check cookie adamt1
server 10.168.168.89 10.168.168.89:80 maxconn 10000 check cookie adamt2
server 10.168.168.35 10.168.168.35:80 maxconn 10000 check cookie adamt3
server 10.168.168.52 10.168.168.52:80 maxconn 10000 check cookie adamt5
server 10.168.168.40 10.168.168.40:80 maxconn 10000 check cookie adamt4
cookie SERVERUSED insert indirect nocache preserve
http-check connect port 443 ssl sni SUB.DOMAIN.co.il
http-check send meth GET uri /lbmanager.aspx ver HTTP/1.1 hdr host SUB.DOMAIN.co.il
server 10.168.168.20 10.168.168.20:443 maxconn 10000 check ssl verify none cookie technion1
server 10.168.168.35 10.168.168.35:443 maxconn 10000 check ssl verify none cookie technion2
server 10.168.168.40 10.168.168.40:443 maxconn 10000 check ssl verify none cookie technion3
http-check connect
server 10.168.168.20 10.168.168.20:80 maxconn 10000 check cookie technion1
server 10.168.168.35 10.168.168.35:80 maxconn 10000 check cookie technion2
server 10.168.168.40 10.168.168.40:80 maxconn 10000 check cookie technion3
i just change for here the subdomain and domain name
