We have some Python websockets, apache2 hosts, and Percona XtraDB Cluster (mysql) hosts behind our proxy. ( HA-Proxy version 2.0.20-1~bpo10+1 2021/01/12 )
The websockets require client certificate authentication. The certificate authority cert and revocation list are kept on the proxy.
Those 2 files are refreshed periodically, and then we run /etc/init.d/haproxy reload-socket. This allows us to load a new configuration without doing a full stop/start and disconnecting users.
However, after a number of these config reloads, the proxy will stop passing traffic until it is rebooted. This freeze condition takes less than 48 hours to recur. Additionally, the mysql hosts also have to reboot before they are able to serve requests as well. It is all pretty bizarre.
Without using reload-socket, things are quite stable for many days. I am wondering if anyone has experienced anything like this, or has any suggestion.
Here is my config:
maxconn 50000
ssl-server-verify none
stats socket /run/haproxy/admin.sock mode 777 level admin expose-fd listeners
maxconn 9999
log 127.0.0.1 local0
log 127.0.0.1 local7 debug
option httpchk
timeout queue 5s
timeout client 36000s
timeout server 36000s
timeout tunnel 1h
/etc/haproxy/crl.pem
bind :1936 ssl crt /etc/haproxy/certs.d/
stats uri /
frontend HTTPS-FRONTEND
bind *:443 ssl crt /etc/haproxy/certs.d/
maxconn 9999
use_backend HTTPS-BACKEND
balance source
cookie serverid insert
option ssl-hello-chk
default-server check maxconn 1000
option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server web001 web001.dfs.c3.domain.com:443 ssl sni ssl_fc_sni check fall 3 rise 2
server web002 web002.dfs.c3.domain.com:443 ssl sni ssl_fc_sni check fall 3 rise 2
server web003 web003.dfs.c3.domain.com:443 ssl sni ssl_fc_sni check fall 3 rise 2
frontend WSS-9876-FRONTEND
bind *:9876 ssl crt /etc/haproxy/certs.d/ ca-file /etc/haproxy/ca.pem verify required crl-file /etc/haproxy/crl.pem
maxconn 9999
http-request set-header X-Forwarded-Ssl on if { ssl_fc }
use_backend WSS-9876-BACKEND
balance source
option tcp-check
server comm001 comm001.dfs.c3.domain.com:9876 ssl check fall 3 rise 2
server comm002 comm002.dfs.c3.domain.com:9876 ssl check fall 3 rise 2
server comm003 comm003.dfs.c3.domain.com:9876 ssl check fall 3 rise 2
frontend WSS-9877-FRONTEND
bind *:9877 ssl crt /etc/haproxy/certs.d/
maxconn 9999
use_backend WSS-9877-BACKEND
balance source
option tcp-check
server comm001 comm001.dfs.c3.domain.com:9877 ssl check fall 3 rise 2
server comm002 comm002.dfs.c3.domain.com:9877 ssl check fall 3 rise 2
server comm003 comm003.dfs.c3.domain.com:9877 ssl check fall 3 rise 2
frontend MYSQL-FRONTEND
bind *:3306
maxconn 9999
use_backend MYSQL-BACKEND
option tcp-check
server db001 db001.dfs.c3.domain.com:3306 check fall 3 rise 2
server db002 db002.dfs.c3.domain.com:3306 check fall 3 rise 2
server db003 db003.dfs.c3.domain.com:3306 check fall 3 rise 2
