Websockets transition during graceful reload
My problem is that I use websockets with stick-tables and need to periodically update the configuration using external tool. As I understand this process, I will have several PIDs while connections are established, but this doesn’t work as described. Each time I reload the configuration, websocket connection is being dropped.
Reload command:
kill -USR2 `cat /etc/haproxy/haproxy.pid`
Configuration snippet:
  pidfile /etc/haproxy/haproxy.pid
  master-worker
  mworker-max-reloads 20
  log stdout local0
  maxconn 500000
  stats socket /var/run/haproxy.sock mode 660 level admin
  nbproc 1
  nbthread 2
  cpu-map auto:1/1-2 0-1
  timeout client 10s
  timeout server 60s
  timeout client-fin 1s
  timeout server-fin 1s
  timeout http-request 10s
  timeout http-keep-alive 300s
peers local
  peer haproxy haproxy:1024
frontend stats
  bind :32600
  option http-use-htx
  option dontlog-normal
  stats uri /
  stats refresh 20s
frontend https-in
  bind *:8433 accept-proxy
  # Define hosts
  acl host hdr(host) -i doman.com
  ## figure out which one to use
  use_backend servers if host
frontend http-in
  bind :8080 accept-proxy
backend servers
  http-request set-header X-Real-IP %[src];
  http-request set-header X-Forwarded-For %[src];
  http-request set-header X-Forwarded-Proto %[src];
  http-request set-header Connection "upgrade"
  http-request set-header Host %[src]
  stick-table type string len 80 size 1m expire 8h peers local
  stick on url_param(mrid)
  timeout server  120s
  server1 adress1
  server2 adress2
Can you help to find if there are another way of graceful termination? Or maybe any thoughts on this topic?
We have fixed this issue. Actully, the problem was that we haven’t set tunnel timeout. WS pings weren’t able to keep up with client timeout we have set.
