Hi all,
I’m trying to use haproxy for ssl auth so: client —ssl ----> haproxy --no ssl–> service (grpc)
Locally it works great, but while using docker compose things seems to fail.
ha.cfg:
tune.ssl.default-dh-param 1024
timeout connect 10000ms
timeout client 60000ms
timeout server 60000ms
frontend fe_https
bind *:8444 ssl ca-file /keys/server.cert crt /keys/server.pem alpn h2,http/1.1
default_backend be_grpc
backend be_grpc
server s1 grpc-server:1337
Docker-compose:
version: "3"
services:
grpc-server:
image: us.gcr.io/rookout/grpc-no-ssl:1
command: ["python","app/server.py"]
haproxy:
environment:
- EXTRA_GLOBAL_SETTINGS=debug
image: us.gcr.io/rookout/haproxy
links:
- grpc-server
ports:
- 8444:8444
Does any one know what can be the reason for it to work locally (macbook HA-Proxy version 1.8.4-1deb90d 2018/02/08
Copyright 2000-2018 Willy Tarreau willy@haproxy.org)
But not as part of docker?
Thanks,
Itiel.
