I have used below configuration to configure grpc with ssl in haproxy.cfg.
Still not able to request grpc service with ssl. Client gives error “14 UNAVAILABLE: failed to connect to all addresses”. Using bloomRPC as client.
haproxy.cfg:
option http-use-htx
frontend http_front
bind *:443 ssl crt /home/cso/Downloads/latest_ang_certs/local_com.pem
stats uri /haproxy?stats
default_backend http_back
backend http_back
server search_be_service localhost:4048 check proto h2
