Hello community,
I’m seeing a very small number (0.0025%, ~20-30 req out of 800-1000K daily) of POST requests just being shut down without any response from haproxy:
- The HTTP client has a pool of persistent connections (apache http client 4.5.5)
- HTTP Client is able to send the whole POST request to haproxy
- When HTTP client tries to read the response, haproxy seems to send empty response (or no response at all, this results in an org.apache.http.NoHttpResponseException).
- While checking the access logs of backends I can see, that the failed requests never hit the backends.
I wonder what could be the possible hiccup here, initially I thought that configuring haproxy with smaller timeout http-keep-alive would help to avoid a possible (imaginary) race condition, when the backend closes the connection right when haproxy starts forwarding it, but seems like it didn’t help.
Setup:
- 2 backends running Apache Tomcat 8.0.33, (connectionTimeout = 20 sec, keepAliveTimeout = 20 sec)
The config:
backend somebackend
description http:8080
option httpchk GET /status
http-check expect status 200
default-server inter 250 fall 3 weight 100
timeout server 66000
timeout http-keep-alive 15s
server service1 {address1} check
server service2 {address2} check
option dontlog-normal
timeout client-fin 600s
timeout tunnel 1h
frontend main
bind *:8080-8081
maxconn 6000
use_backend somebackend if { hdr_beg(host) -i old-name.local }
use_backend somebackend if { hdr_beg(host) -i current-name.local }
use_backend somebackend if { hdr_beg(host) -i a-very-old-name.local }
Edit: There’s a reason why I’ve specified that POST requests are being treated like that. Looking at the haproxy source code I’ve noticed some code that allows interop with older browsers:
/* POST requests may require to read extra CRLF sent by broken
* browsers and which could cause an RST to be sent upon close
* on some systems (eg: Linux). */
channel_auto_read(req);
Similar POST request tweaks are located in a few places as well, not sure if this could potentially affect things. I’ll also have to note that most of the HTTP requests sent to backends via haproxy are POST requests. Could there be a rare race condition when two consequent POST requests could be read, but only first one handled?
