haproxy version: 2.0.17
We found the client received some 504 errors, less than 1/10000. Thus, we take a tcpdump and follow the stream, found that when haproxy completes a request, it does not disconnect to client after more than 40s (timeout http-keep-alive is 20s), and accepted a new request in this connection, and then quickly returned a 504 error to client. We tracked the problem request and found that haproxy has routed the request to the server, but quickly sent a RST to the server to disconnect.
I have two question:
1、In connection clinet to haproxy,Why not haproxy disconnect even if it times out?
2、In connection haproxy to server, why does haproxy sent RST quickly?
picture 1(client to haproxy, .193 is client and .135 is ha)
picture 2(haproxy to server, .135 is ha and .184 is server)
cfg:
maxconn 25000
maxconnrate 3000
log 127.0.0.1 local1 err
pidfile /var/run/haproxy.pid
nbproc 1
noreuseport
server-state-file /var/run/server_state
spread-checks 20
maxconn 25000
timeout client 30s
timeout server 30s
retries 2
timeout http-keep-alive 20s
http-reuse safe
option accept-invalid-http-response
no option http-use-htx
listen MONITOR
bind 0.0.0.0:12345
stats refresh 30s
stats uri /haproxy_stats
stats auth test:test
stats hide-version
monitor-uri /haproxy_healthcheck
frontend VS_12633
bind 0.0.0.0:12633
bind [::]:12633 v6only
use_backend %[path, map_beg(/etc/haproxy/conf/VS_12633. map)] if { path, map_beg(/etc/haproxy/conf/VS_12633. map) -m found }
backend BE_WEB1
timeout server 30s
option forwardfor except 127.0.0.1 if-none
option httpchk GET /test/Check.html
http-check expect string check_ok
server srv1 123.45.67.181:80 check inter 4000 rise 3 fall 3
server srv2 123.45.67.182:80 check inter 4000 rise 3 fall 3
backend BE_WEB2
timeout server 30s
server srv3 123.45.67.183:80 check inter 4000 rise 3 fall 3
server srv4 123.45.67.184:80 check inter 4000 rise 3 fall 3
server srv5 123.45.67.185:80 check inter 4000 rise 3 fall 3
