I am setting up a reverse proxy that handles request target.com.mirror.abc.xyz:8888 and acts as the man in the middle between a client and target.com:8888. It also respects the original scheme of request, so that HAProxy serves https://target.com.mirror.abc.xyz:8888 with backend https://target.com:8888, and serves http://target.com.mirror.abc.xyz:8888 with backend http://target.com:8888.
To do so, I plan to detect and log the original scheme in a custom header like $tell-ngx-ori-scheme, so that I can implement such a reverse proxy by NGINX configuration proxy_pass $tell-ngx-ori-scheme$real_host$request_uri;
The way I used to detect original scheme is http-request set-var(txn.l7_fetch_proto) url,regsub(\"(^[^\/:]*:\/\/)\",\"\1\",i)
It should work, like this:
(If you are having problem loading this image, please refer to:https://regex101.com/r/dN3UYR/1)
However, when I test this configuration with curl, the logged custom var l7_fetch_proto shown as empty str "".
While I dig deeper, it appears as only the request comes from curl will cause fetched url segment to be empty str, while logs of browser access history are all shown proper url and base record.
Would someone please tell me how this situation could happen? Here is the full configuration I wrote:
stats socket /var/run/haproxy.sock mode 0640 expose-fd listeners level admin
stats timeout 2m
log stdout format rfc5424 local0 info
option http-use-htx
timeout client 30s
timeout client-fin 5s
timeout server 30s
timeout server-fin 5s
timeout queue 30s
timeout http-request 5s
timeout http-keep-alive 2s
timeout tunnel 2m
resolvers mydns
nameserver quad91 9.9.9.11:53
nameserver quad92 149.112.112.11:53
frontend fe_main
bind :80
bind :443 ssl crt-list /etc/haproxy/crt-list.txt
option logasap
log-format "%{+Q}o %{-Q}ci - - [%trg] %r %ST %B \"\" \"\" %cp %ms %ft %b %s %TR %Tw %Tc %Tr %Ta %tsc %ac %fc %bc %sc %rc %sq %bq %CC %CS %hrl %hsl \"striped_dom:\" %[var(txn.striped_dom)] \"ip_striped_dom:\" %[var(txn.ip_striped_dom)] \"l7_fetch_base:\" %[var(txn.l7_fetch_base)] \"l7_fetch_url:\" %[var(txn.l7_fetch_url)] \"l7_fetch_proto:\" %[var(txn.l7_fetch_proto)]"
http-request set-var(txn.striped_dom) req.hdr(Host),regsub(\"(^.+)\.mirror\.abc\.xyz(:\d+)?\",\"\1\2\",i)
http-request do-resolve(txn.ip_striped_dom,mydns) var(txn.striped_dom)
http-request set-var(txn.l7_fetch_url) url
http-request set-var(txn.l7_fetch_base) base
# redirect scheme https code 301 if !{ ssl_fc }
# http-response set-header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload"
default_backend rp-mirror-backend
http-request deny if { var(txn.ip_striped_dom) -m ip 10.0.0.0/8 127.0.0.0/8 100.64.0.0/10 172.16.0.0/12 192.0.0.0/24 192.168.0.0/16 198.18.0.0/15 ::1/128 fc00::/7 }
http-request set-header Host %[var(txn.striped_dom)]
http-request set-header tell-ngx-ori-scheme %[var(txn.l7_fetch_proto)]
server nginx 127.0.0.1:9999 send-proxy-v2-ssl-cn proxy-v2-options crc32c
## http-request set-dst var(txn.ip_striped_dom)
## http-request set-dst-port int(80)
## server rp-mirror 0.0.0.0:0
