The backend is not forwarding traffic to the server and returns 503 service unavailable.
My server requires the exact URL and headers. If the header is not set, the server will return 401 unauthorized and if the URL is not set, the server will return 404 Not found.
My cfg file
log 127.0.0.1 local0 debug
pidfile /var/run/haproxy.pid
maxconn 1000
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend main 0.0.0.0:80
option httpclose
http-request add-header X-Forwarded-Proto http
default_backend app
backend app
server app1 100.82.185.122:32401
I am testing as following
import csv
import requests
import time
#url='http://100.82.185.122:32401/services/collector/event' #DIRECT URL
url='http://100.82.182.73/services/collector/event' #HA Proxy URL
authHeader = {'Authorization': 'Splunk {}'.format('f64e68e1-a6e4-46a1-8fe3-131023886841')}
reader = csv.DictReader(open('overheating_.csv'))
for row in reader:
#row['SystemUsage.AggregateUsage'] = 17
#row['FanSensor.RPMReading'] = 3
jsonDict = {"index":"dltk-test", "source":"csv", "sourcetype":"all-idrac", "event": row }
#print (row)
r = requests.post(url, headers=authHeader, json=jsonDict, verify=False)
print (r.text)
time.sleep(1)
Response
<html><body><h1>503 Service Unavailable</h1>
</body></html>
HAProxy Logs
Jun 28 15:30:51 localhost haproxy[25389]: 100.82.183.41:41182 [28/Jun/2022:15:30:51.906] main app/app1 0/0/-1/-1/0 503 212 - - SC-- 0/0/0/0/3 0/0 "POST /services/collector/event HTTP/1.1"
Jun 28 15:30:52 localhost haproxy[25389]: 100.82.183.41:41184 [28/Jun/2022:15:30:52.913] main app/app1 0/0/-1/-1/0 503 212 - - SC-- 0/0/0/0/3 0/0 "POST /services/collector/event HTTP/1.1"
Please guide me what’s wrong here.
