I have an issue with my loadbalanced percona setup. The issue only rears its head when there is a large amount of data being inserted into the database during a transaction, it fails at the commit stage, it seems as if the connection times out but it happens no matter what I raise the timeouts to. There is no issue when I hit one of the percona nodes directly, and I have set the haproxy config to write to 1 node only. As it works when I hit the percona node directly it seems the issue is with my haproxy configuration. Here it is, any help greatly appreciated:
maxconn 4096
option tcp-smart-accept
option tcp-smart-connect
maxconn 40000
timeout check 3500ms
timeout queue 3500ms
timeout connect 3500ms
timeout client 10000ms
timeout server 10000ms
bind 10.100.2.11:9000
stats hide-version
stats realm HAproxy-Statistics
stats uri /haproxy_stats
stats auth
listen percona_cluster_write
bind 10.100.2.11:3306
timeout client 1m
timeout server 1m
option mysql-check
server DB01-QA 10.100.3.11:3306 send-proxy check inter 12000 rise 3 fall 3
server DB01-QA 10.100.3.12:3306 send-proxy check inter 12000 rise 3 fall 3 backup
server DB01-QA 10.100.3.13:3306 send-proxy check inter 12000 rise 3 fall 3 backup
listen percona_cluster_read
bind 10.100.2.11:3307
option mysql-check
server DB02-QA 10.100.3.12:3306 send-proxy check inter 12000 rise 3 fall 3
server DB03-QA 10.100.3.13:3306 send-proxy check inter 12000 rise 3 fall 3
Here is error I get from application:
Fatal error encountered during command execution.
MySql.Data.MySqlClient.MySqlException (0x80004005): Fatal error encountered during command execution. —> MySql.Data.MySqlClient.MySqlException (0x80004005): Fatal error encountered attempting to read the resultset. —> MySql.Data.MySqlClient.MySqlException (0x80004005): Reading from the stream has failed. —> System.IO.EndOfStreamException: Attempted to read past the end of the stream.
at MySql.Data.MySqlClient.MySqlStream.ReadFully(Stream stream, Byte[] buffer, Int32 offset, Int32 count)
at MySql.Data.MySqlClient.MySqlStream.LoadPacket()
at MySql.Data.MySqlClient.MySqlStream.ReadPacket()
at MySql.Data.MySqlClient.NativeDriver.GetResult(Int32& affectedRow, Int64& insertedId)
at MySql.Data.MySqlClient.Driver.NextResult(Int32 statementId, Boolean force)
at MySql.Data.MySqlClient.MySqlDataReader.NextResult()
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader(CommandBehavior behavior)
at MySql.Data.MySqlClient.MySqlCommand.ExecuteNonQuery()
at MySql.Data.MySqlClient.MySqlTransaction.Commit()
