Hi there,
I’m using HAProxy for SSL termination for a Plex server. Unfortunately I can’t get this setup to work correctly. While I can successfully connect through the proxy and start streaming, the stream is lagging very hard. In the Plex Dashboard I can see that the bandwidth is capped at ~10 MBits and the bandwidth graph has a tooth pattern (ranging from 0 to 10 MBits). As soon as I remove HAProxy from the equation, the graph looks more like a flat line and correctly settles at about 25 MBits (which is what I’ve configured as the limit in Plex itself).
Any ideas what I could try?
This is my current config:
log stdout format raw local0
maxconn 100000
nbthread 4
timeout client 30s
timeout server 30s
maxconn 10000
frontend www-no-cache
bind :2096 ssl crt /certs/DOMAIN.de.all.pem
option forwardfor if-none
http-request replace-header x-forwarded-for ^ "%[req.fhdr(x-forwarded-for)], %[src]"
use_backend plex.DOMAIN.de if { req.hdr(host) -i plex.DOMAIN.de:2096 }
default_backend access_denied
resolvers default
parse-resolv-conf
http-request deny
server s1 plex.lan.DOMAIN.de:32400 resolvers default
