I am trying to use HAProxy for TLS termination and some extra http rules in front of varnish cache. For some weird reason, whenever I have used HAProxy in front of any caching server, it does not buffer anything ( and I think that’s what the issue is here because nginx works just fine, but I cannot use it ), and there is no official resource that assures whether or not HAProxy can actually buffer response bodies or not in the first place.
Both servers are using bbr congestion algorithm and have high ulimit settings. I have also tested the servers with a high 100 segment initial tcp window all the way down to the default 10. Of course, I have also played around with the wmem rmem buffers on both servers. None of these settings changed anything.
The HAProxy and Varnish server are both running Fedora 39 and talk to each other via a local interface.
haproxy -vv
HAProxy version 2.9-dev11-2fb1776 2023/11/24 - https://haproxy.org/
Status: development branch - not safe for use in production.
Known bugs: https://github.com/haproxy/haproxy/issues?q=is:issue+is:open
Running on: Linux 6.5.12-300.fc39.x86_64 #1 SMP PREEMPT_DYNAMIC Mon Nov 20 22:44:24 UTC 2023 x86_64
TARGET = generic
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_THREAD=1 USE_OPENSSL_WOLFSSL=1 USE_QUIC=1
Feature list : -51DEGREES -ACCEPT4 -BACKTRACE -CLOSEFROM -CPU_AFFINITY -CRYPT_H -DEVICEATLAS -DL -ENGINE -EPOLL -EVPORTS -GETADDRINFO -KQUEUE -LIBATOMIC -LIBCRYPT -LINUX_CAP -LINUX_SPLICE -LINUX_TPROXY -LUA -MATH -MEMORY_PROFILING -NETFILTER -NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC +OPENSSL_WOLFSSL -OT -PCRE -PCRE2 -PCRE2_JIT -PCRE_JIT +POLL -PRCTL -PROCCTL -PROMEX -PTHREAD_EMULATION +QUIC -QUIC_OPENSSL_COMPAT -RT -SHM_OPEN +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 -SYSTEMD -TFO +THREAD -THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=1).
Built with OpenSSL version : wolfSSL 5.6.4
Running on OpenSSL version : wolfSSL 5.6.4
OpenSSL library supports : SSLv3 TLSv1.0 TLSv1.1 TLSv1.2 TLSv1.3
Built without PCRE or PCRE2 support (using libc's regex instead)
Encrypted password support via crypt(3): no
Built with gcc compiler version 13.2.1 20231011 (Red Hat 13.2.1-4)
Total: 2 (2 usable), will use poll.
quic : mode=HTTP side=FE mux=QUIC flags=HTX|NO_UPG|FRAMED
Available services : none
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
I have tested this on multiple operating systems and different haproxy versions etc. with the same results, so I do not think this has to do with any specific haproxy version. I have tried messing with nodelay, request buffering, changing the maxrewrite and other buf values, but I was still unable to fix the issue. The only way I was able to make it act normal was to use maxconn 1 on the backend, but obviously that would never work in production.
Here is my problem. Note: all of those objects are warm in varnish cache.
Ideally, it would stream every object at once like this:
Or buffer everything like this:
(In all of the above photos, I am loading a page with 250 50kb images, from a 100mbps connection and 12ms latency)
My basic config. Of course, I have messed around with option http-no-delay, option http-buffer-request, option http-keep-alive, http-reuse always/safe.
maxconn 12000
timeout server 30s
timeout client 30s
listen http
bind :443 ssl crt /root/mycert.pem alpn h2,http/1.1
server s1 ip.ip.ip.ip:80
Can anyone guide me on how I can get HAProxy to send objects more consistently, or whether or not this is even possible to fix?
Thanks in advance!
