Haproxy pauses the flow. help needed
Hi. A mobile app has the following connection chain:
mobile app (https) → AWS NLB (tcp/443) → haproxy on EC2 instance (https) → AWS ALB (http) → backend on AWS Fargate
I’ve discovered that sometimes while haproxy is sending traffic to the ALB it pauses the transfer for an unknown reason for several seconds (or even several tens of seconds):
(can share the full pcap dump if needed)
It happens only for a fraction of requests and mostly during high peaks of customer traffic.
Here is the relevant haproxy and ALB logs:
Sep  3 15:20:31 141.214.x.y:13971 [03/Sep/2024:15:20:22.467] lb-useast~ apielb_backend/api-elb3 0/1736/0/0/2/7662/9400 ---- 60/60/6/3/0 0/0 "POST https://domain.com/ls/apiLocation/location HTTP/2.0" 200 {|||||domain.com||549|Mozilla/5.0 (iPhone; CPU iPhone OS 17_6_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko} ireq_size=958 resp_size=123 172.31.93.169:4443 3.229.x.y:443 ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2
https 2024-09-03T15:20:31.868632Z app/ecs-prod/fa267007e 54.156.x.y:48588 172.31.80.84:80 7.655 0.005 0.000 200 200 1068 143 "POST https://domain.com:443/ls/apiLocation/location HTTP/1.1" "Mozilla/5.0 (iPhone; CPU iPhone OS 17_6_1 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) [Optional(VirtueTrack) 1.118]" ECDHE-RSA-AES128-GCM-SHA256 TLSv1.2 arn:aws:elasticloadbalancing:us-east-1:2770xxxxx:targetgroup/ecs-prod-fg-locationserver/dfa1459540 "Root=1-66d72938-062b422f6a970fb4" "-" "session-reused" 335 2024-09-03T15:20:24.207000Z "waf,forward" "-" "-" "172.31.80.84:80" "200" "-" "-" TID_9c7aa4736266674d823
Please, help me find a reason for that and fix.
# uname -r
4.14.350-266.564.amzn2.x86_64
# haproxy -vv
HAProxy version 3.0.3-95a607c 2024/07/11 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2029.
Known bugs: http://www.haproxy.org/bugs/bugs-3.0.3.html
Running on: Linux 4.14.350-266.564.amzn2.x86_64 #1 SMP Sat Aug 10 09:56:03 UTC 2024 x86_64
  TARGET  = linux-glibc
  CC      = cc
  CFLAGS  = -O2 -g -fwrapv
  OPTIONS = USE_THREAD=1 USE_LINUX_TPROXY=1 USE_OPENSSL=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1 USE_PROMEX=1 USE_PCRE=1 USE_PCRE_JIT=1
  DEBUG   =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY -LUA -MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_AWSLC -OPENSSL_WOLFSSL -OT +PCRE -PCRE2 -PCRE2_JIT +PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC -QUIC_OPENSSL_COMPAT +RT +SHM_OPEN -SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL +ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=2).
Built with OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips  26 Jan 2017
Built with gcc compiler version 7.3.1 20180712 (Red Hat 7.3.1-17)
        [BWLIM] bwlim-in
        [BWLIM] bwlim-out
        [FCGI] fcgi-app
HAProxy config (meaningful parts):
    maxconn     25000
    master-worker
    set-var proc.max_conn_cur int(500)
    set-var proc.max_conn_rate int(2000)
    set-var proc.max_http_err_rate int(200)
    set-var proc.max_http_req_rate int(5000)
    ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-
GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
    ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES25
6-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
  option dontlognull            # don't log sessions even if no data exchange happened
  option splice-auto            # accelerate performance with kernel tcp splicing options
  option httplog                # enable logging of HTTP request, session state and timers
  option http-server-close      # operate in http-close mode
  option redispatch             # allow switching to another backend server when the one in the cookie gets down
  option contstats              # enable continuous traffic statistics updates
  backlog 25000                 # correlates with maxconn
  timeout client          60s   # was 120
  timeout client-fin      15s   # was 25
  timeout connect          5s
  timeout server           1h   # was 60s
  timeout tunnel           1h
  timeout http-keep-alive 10s   # was 1
  timeout http-request     5s   # was 15
  timeout queue           30s
  timeout tarpit          60s
  timeout check            5s
  default-server inter 6s rise 1 fall 3
  log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Th/%Ti/%TR/%Tw/%Tc/%Tr/%Tt\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %{+Q}r\ %ST\ "%hr"\ ireq_size=%U\ resp_size=%B\ %fi:%fp\ %si:%sp\ %sslc\ %sslv
frontend lb-useast
  maxconn 8000
  bind *:4080 name lb-useast_frontend_http
  bind *:4443 name lb-useast_frontend ssl crt-list /mnt/s3vol-common/crt/crt-list.txt
  tcp-request connection track-sc0 src
  stick-table type ip size 500k expire 30s store conn_cur,conn_rate(10s),http_req_rate(10s),http_err_rate(10s)
  tcp-request connection reject if { src -f /etc/haproxy/blacklist.lst }
  # CVE-2023-25725 workaround
  http-request deny if { fc_http_major 1 } !{ req.body_size 0 } !{ req.hdr(content-length) -m found } !{ req.hdr(transfer-encoding) -m found }
  # Reject the new connection if the client already has proc.max_conn_cur opened
  http-request add-header X-Haproxy-ACL %[req.fhdr(X-Haproxy-ACL,-1)]over-%[var(proc.max_conn_cur)]-active-connections, if { sc0_conn_cur,sub(proc.max_conn_cur) gt 0 }
  http-request capture sc0_conn_cur len 4 if { sc0_conn_cur,sub(proc.max_conn_cur) gt 0 }
  # Reject the new connection if the client has opened more than proc.max_conn_rate connections in 10 seconds
  http-request add-header X-Haproxy-ACL %[req.fhdr(X-Haproxy-ACL,-1)]over-%[var(proc.max_conn_rate)]-connections-in-10-seconds, if { sc0_conn_rate,sub(proc.max_conn_rate) gt 0 }
  http-request capture sc0_conn_rate len 4 if { sc0_conn_rate,sub(proc.max_conn_rate) gt 0 }
  # Reject the connection if the client has passed the HTTP error rate
  http-request add-header X-Haproxy-ACL %[req.fhdr(X-Haproxy-ACL,-1)]high-error-rate, if { sc0_http_err_rate(),sub(proc.max_http_err_rate) gt 0 }
  http-request capture sc0_http_err_rate() len 4 if { sc0_http_err_rate(),sub(proc.max_http_err_rate) gt 0 }
  # Reject the connection if the client has passed the HTTP request rate
  http-request add-header X-Haproxy-ACL %[req.fhdr(X-Haproxy-ACL,-1)]high-request-rate, if { sc0_http_req_rate(),sub(proc.max_http_req_rate) gt 0 }
  http-request capture sc0_http_req_rate() len 4 if { sc0_http_req_rate(),sub(proc.max_http_req_rate) gt 0 }
  # Insert a unique request identifier in the headers of the request
  # passed to the backend
  unique-id-format %{+X}o\ %ci:%cp_%fi:%fp_%Ts_%rt:%pid
  unique-id-header X-Unique-ID
  declare capture request len 256
  http-request capture req.fhdr(X-Haproxy-ACL) id 0
  capture request header Host len 64
  capture request header Referer len 164
  capture request header Content-Length len 10
  capture request header User-Agent len 96
  #-- strip out the port part of the Host header
  http-request set-header host %[hdr(host),field(1,:)]
  use_backend alb_backend
backend alb_backend
  # Remove the ACL header
  http-request del-header ^X-Haproxy-ACL
  server-template alb 5 alb.domain.com:443 ssl verify none check port 443 resolvers aws
The instance is not overloaded or something:
11:40:01 AM     CPU     %user     %nice   %system   %iowait    %steal     %idle
03:10:01 PM     all      2.42      0.00      2.12      0.06      1.79     93.61
03:20:01 PM     all      2.85      0.00      2.20      0.07      1.81     93.06
03:30:01 PM     all      2.81      0.00      2.04      0.12      1.71     93.32
resolved by myself: that happened with slow (mobile) clients only. setting up option http-buffer-request did the trick
