Haproxy - backend with ADS is failing during authentication
Hello All!
Please help me on following usecase.
Requirement: I must load balance a similar backend Web UI’s running on 3 VMs. This web ui required to authenticate in Microsoft ADS; to further browse through UI. Its https end point.
Current Issue: I have configured frontend and backend and able to access landing web page of that web UI. I can provide username and password; but login fails saying username/password is wrong. [If try web ui directly and able to login successfully with same username & password.]
Environment Details:
HAProxy version 2.4.9-f8dcd9f 2021/11/24
Red Hat Enterprise Linux release 8.4 (Ootpa)
Config:
backend mapr_mcs
option ssl-hello-chk
server 10.11.18.121 10.11.18.121:8343 maxconn 200 check
server 10.11.18.131 10.11.18.131:8343 maxconn 200 check
frontend mapr_mcs
bind *:8343
maxconn 2000
default_backend mapr_mcs
trying using stickiness
https://www.haproxy.com/documentation/hapee/latest/onepage/#4-stick-table
https://www.haproxy.com/documentation/hapee/latest/onepage/#4-stick%20on
