Dear good, nice to greet you and thank you in advance for your answer, I will use the google translator, excuse me for the writing mistakes. I commented that I maintain a haproxy configuration based on operating system rhel 7.4 and HA-Proxy version 1.5.18.
In relation to the configuration, I have 4 balanced sites, the incident is presented when consuming a service which performs a https redirection and invokes a simple authentication that is done within a weblogic osb “esb.vtr.cl”, I attach the complete configuration of the proxy, in addition to the configuration by weblogic, I hope to receive news soon from you thanked.
When performing tests on http and https without authentication does not present any inconvenience, please support
Haproxy configuration
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 10000
stats socket /var/run/haproxy.sock mode 600 level admin
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 10000
stats uri /stats
stats auth admin:admin
frontend http-ddrservice
bind 172.17.113.4:80
default_backend vtrddrservicecluster-backend
frontend http-esb
bind 172.17.113.5:80
default_backend esb-vtresbcluster-backend
#acl host_esb hdr(host) -i esb.vtr.cl
#use_backend esb-vtresbcluster-backend if host_esb
#acl host_eps hdr(host) -i eps.vtr.cl
#use_backend eps-vtrepscluster-backend if host_eps
#acl host_ddrservice.vtr.cl hdr(host) -i ddrservice.vtr.cl
#use_backend vtrddrservicecluster-backend if host_ddrservice.vtr.cl
#acl host_visordeboleta.vtr.cl hdr(host) -i visordeboleta.vtr.cl
#use_backend vtrvisorboletacluster-backend if host_visordeboleta.vtr.cl
frontend http-eps
bind 172.17.113.6:80
default_backend eps-vtrepscluster-backend
frontend http-visorboleta
bind 172.17.113.7:80
default_backend vtrvisorboletacluster-backend
frontend https-esb
bind 172.17.113.5:443 ssl crt /etc/cert/esb.vtr.cl.pem
http-request set-header X-Request-Start t=%Ts%ms
http-request set-header Host esb.vtr.cl
server vtresb01_tigris tigris.vtr.cl:7011 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server vtresb02_yukon yukon.vtr.cl:7011 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server vtresb03_eufrates eufrates.vtr.cl:7011 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server vtresb04_arkansas arkansas.vtr.cl:7011 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
cookie JSESSIONID prefix ## manejo de sesiones
#cookie SERVERID insert indirect nocache ## manejo de sesiones
#redirect scheme https if !{ ssl_fc }
hash-type consistent # afinidad dentro de HAProxy
server belaya.vtr.cl belaya.vtr.cl:8280 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server cimarron.vtr.cl cimarron.vtr.cl:8280 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server svmovilprod01_ural ural.vtr.cl:9081 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server svmovilprod02_angara angara.vtr.cl:9081 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server vboleta01_murray murray.vtr.cl:8001 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
server vbpresprod02_aldan aldan.vtr.cl:8001 check inter 5000 fastinter 1000 fall 1 rise 1 weight 1 maxconn 10000
[root@muerto ~]#
Simple authentication osb weblogic service
Cliente autentication “basic”
Display Policy “Empty”
Ecuest Encoding “Empty”
Error presented
