we have some custom applications that send their logs (so far) via unencrypted tcp (simple JSON).
We would like to collect those using a Logstash in front of an Elastic Cluster.
Since we have multiple Logstashes we’re also using HAProxy in front of them.
Now, we would like to encrypt the whole log traffic using TLS.
What works:
- sending unencrypted via HAProxy (though undesired)
- using HAProxy as a transparent Layer 4 (tcp) Proxy and configure TLS on the Logstashes
- using HAProxy as a Layer 4 (tcp) Proxy and configure TLS on HAProxy as well as on the Logstashes
The problem with solutions 2 and 3 are, that while the transport encryption works fine, we only see our HAProxy as the source of our logs in Logstash.
A solution for this (so we thought) was enabling the PROXY Protocol in HAProxy and in Logstash (which, according to documentation, only seems to understand PROXY v1).
So in our HAProxy Config, we enabled send-proxy in the according backend server line and enabled proxy_protocol => true in the according logstash tcp input config.
Logstash config:
input {
tcp {
port => 1234
codec => "json_lines"
ssl_enable => true
ssl_verify => false
ssl_key => "/etc/ssl/certs/host.key"
ssl_cert => "/etc/ssl/certs/host.crt"
relevant HAProxy config:
frontend logstash
bind *:1234
use_backend logstash
backend logstash
server logstash1 logstash1.example.com send-proxy
server logstash2 logstash2.example.com send-proxy
However, in both configurations (transparent and SSL bridge), Logstash gives the following error:
[2020-01-31T14:04:21,032][ERROR][logstash.inputs.tcp ] Error in Netty pipeline: io.netty.handler.codec.DecoderException: javax.net.ssl.SSLHandshakeException: error:100000f7:SSL routines:OPENSSL_internal:WRONG_VERSION_NUMBER
It seems to me that HAProxy encapsulates the TLS message in a Proxy Protocol header and Logstash expects it the other way around.
Is there anything we could do on HAProxy side to configure the encapsulation order?
Maybe there are other ways to make the original log source known to logstash via HAProxy while retaining the benefits of a redundant loadbalancer.
Thanks for your ideas and help!
