Haproxy in front of elasticsearch rest api on multinode cluster? KeepAlive Issue?
Hi I’ve setup a 3 node elasticsearch cluster on different VMs locally on my laptop.
I use haproxy for loadbalancing.
Connecting curl or kibana against the loadbalancer works fine, but logstash’s monitoring pipeline is giving errors. I did not test with the real pipeline yet.
Looks for me as if logstash wants to keep the connection open but with haproxy in the chain the connection gets closed and logstash seems not to recognize the closure correctly (or it is not forwarded to logstash correctly). So it hits an error and after a while it reconnects again.
I hope anyone of you is using haproxy in front of elasticsearch’s rest api and you can provide your configuration. I am new to haproxy.
Mine looks like this:
    log         127.0.0.1 local2 debug
    log         127.0.0.1 local0 debug
    chroot      /var/lib/haproxy
    maxconn     4000
    user        haproxy
    group       haproxy
    tune.ssl.default-dh-param   2048
    mode                    http
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
frontend ft_elasticsearch_http
    option tcpka
    bind 0.0.0.0:9201 name elasticsearch_http
    default_backend bk_elasticsearch_http
    option httpchk HEAD / HTTP/1.1\r\nAuthorization:\ Basic\ aGVhbHRoY2hlY2s6aGVhbHRoMQ==
    http-check expect status 200
    option tcpka
    default-server fall 2
    balance source
    option log-health-checks
    default-server inter 1s fall 2
    #server elastic03.internal.de_9200 elastic03.internal.de:9200  check check-ssl verify required ca-file /etc/haproxy/certs/ca/elasticsearch/elastic.pem inter 2s
    #server elastic02.internal.de_9200 elastic02.internal.de:9200  check check-ssl verify required ca-file /etc/haproxy/certs/ca/elasticsearch/elastic.pem inter 2s
    server elastic01.internal.de_9200 elastic01.internal.de:9200  check check-ssl verify required ca-file /etc/haproxy/certs/ca/elasticsearch/elastic.pem inter 2s
When I wireshark the connection without loadbalancer in the chain, I can see tcp keepalives, but with haproxy in between, I don’t see any.
Thanks a lot, Andreas
