Hi all,
I am trying to use HAProxy to receive syslogs from Linux servers running rsyslog (tcp) and send them load balanced to multiple backend Logstash servers. While this works and logs are making it to Logstash, I am having issues with rsyslog showing the following error and it drops logs. This does not happen if I connect directly to Logstash. The error is happening every 50 seconds to 1 min consistently. I need a solid connection as these logs are critical. It looks like the drop is coming from HAProxy.
I really need some help with this. Also I need to add in UDP.
The error I receive in rsyslog on the Linux source is shown below
rsyslogd[512557]: omfwd: TCPSendBuf error -2027, destruct TCP Connection to haproxy-fe.example.com:5066
My haproxy.cfg is as follows:
log-tag haproxy
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend frontend_5066
bind *:5066
default_backend backend_5066
server logstash-s1 logstash-s1.example.com:5066 check
server logstash-s2 logstash-s2.example.com:5066 check
server logstash-s3 logstash-s3.example.com:5066 check
server logstash-s4 logstash-s4.example.com:5066 check
