Hi.
I have a load balancer with haproxy on it.
i need the logging to be load balanced on several diffrent servers, so each time a diffrent server would be used…
I can use 1 log specification:
log [server1ip]:514 local0
but i want to use a diffrent server each time, so icould load balance it, using a diffrent server for the logs.
i was thinking about something like this:
frontend main
log 127.0.0.1:60022 local0
listen logger
bind 127.0.0.1:60022
server server1 [server1ip]:514
server server2 [server2ip]:514
server server3 [server3ip]:514
but it doesn’t work…
Using:
tcpdump -i lo
5:32:47.220741 IP localhost.40149 > localhost.60022: UDP, length 187
15:32:47.220762 IP localhost > localhost: ICMP localhost udp port 60022 unreachable, length 223
any ideas? i am ok with a completly diffrent solution as well…
