Load balancing UDP Traffic in HA Proxy
Hi Everyone,
I have simple load balancing scenario.
In my setup, I have HAProxy HA ( haproxy1, haproxy2 ) with a virtual IP (10.0.0.1) and keepalived in both haproxy1, haproxy2.
I am sending the syslogs from a ESX host to the Virtual IP (10.0.0.1), i am able to get the logs in haproxy1 and haproxy2 (checked via tcpdump) from haproxy1/haproxy2, the traffic is not getting forwarded to the backend servers (logstash1, logstash2), all the UDP or TCP ports are open.
I see in few of the posts or blogs about haproxy that the UDP is not supported in it, but to have it get supported, LVS has to be configured at the kernel level to load balance TCP or UDP traffic.
I tried multiple methods to configure LVS in Keepalived to have the traffic forwarded to the backend servers, but could not.
If anybody had encountered issue similar to this, then can you please shed some light into it or share some configs.
The following is the haproxy config and the keep alived configs.
haproxy config:
# Fine-tuned configuration:
nbproc 4 # equal to number of cores
# default maxconn is 2000 (approx)
maxconn 100000
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
#option httplog
    #option  syslog
option	dontlognull
    timeout client  50000
    timeout server  50000
    timeout http-keep-alive 10s
frontend vip
bind 10.10.10.11:5601
default_backend kibana_ui
backend kibana_ui
server prod-efk1.abc.com 10.10.10.1:5601 check
server prod-efk2.abc.com 10.10.10.2:5601 check backup
backend elasticsearch
server prod-es01.abc.com 10.10.10.3:9200 check
server prod-es02.abc.com 10.10.10.4:9200 check backup
server prod-es03.abc.com 10.10.10.5:9200 check backup
backend logstash
# mode tcp
server prod-fag01.abc.com 10.10.10.6:514 check
server prod-fag02.abc.com 10.10.10.7:514 check backup
bind 10.10.10.152:1936
stats hide-version
stats realm LoadBalanced\ ELK\ Components
stats uri /haproxy?stats
stats auth haproxy:haproxy
    maxconn 10
    clitimeout      100s
    srvtimeout      100s
    contimeout      100s
    timeout queue   100s
    stats hide-version
    stats refresh 30s
    stats show-node
    stats uri  /
Keep alived config:
vrrp_script chk_haproxy {
#script “killall -0 haproxy”
#script “/usr/sbin/service haproxy status”
script “/usr/bin/pgrep haproxy”
interval 2
#weight 2
global_defs {
#router_id prod-haproxy01
#lvs_sync_daemon_interface eth0 VI_1
vrrp_instance VI_1 {
interface eth0
state MASTER
virtual_router_id 51
priority 110
unicast_src_ip 10.10.10.8
unicast_peer {
10.10.10.9
virtual_ipaddress {
10.10.10.152 # virtual ip address
track_script {
chk_haproxy
You don’t “get it supported by using LVS”. You are using LVS which is something enterely different than haproxy and does support UDP.
LVS and haproxy have nothing to do with each other. Please ask your question about LVS in the LVS community, for example the LVS mailing list.
Hello Lukastribus,
Thanks for your reply, i felt i have to use LVS along with HA Proxy/Keepalived to load balance UDP Traffic.
If i wanted to load balance UDP traffic through HA Proxy, then is it possible ?, if yes, then can you please share a sample configs ?
I don’t want to use LVS, my focus is only on HA Proxy and i need
Thanks & Regards,
Majid M A
No, haproxy does not support UDP.
Hi Lukastribus,
Many thanks for your reply.
I feel it supports TCP, if you share the sample haproxy for TCP, then it will be really great.
Thanks & Regards,
Majid M A
You are already have that configuration, you posted it yourself.
Doesn’t VMware use UDP/514 by default but have TCP/1514 as the alternate port? Have you considered using that alternate port so that you can continue to receive the logs via HAProxy. In reality, you can configure syslog/rsyslog/syslog-ng to send via UDP or TCP, it is just a change on the sending node. Depending on you logging solution, you also may want to send to a central syslog-ng server farm so you can filter, rewrite, and forward logs into your logging solution as you wish once centrally received.
