I have IOT sensors reporting data to a server
everything reports to a domain name.
I need to put ha proxy to distribute load using sticky sessions
most IOT sensors use TCP, but some use UDP
I’m ok with just passing UDP through HA proxy without load balancing, but not sure if its possible?
What would HA proxy do if I send UDP traffic, can i just forward it on?..this is my first HA proxy server so perhaps there is something at OS level that does this instead?
Thanks, given my scenario, is there a solution you can suggest? or should i be looking at a different solution
I’m not interested in balancing UDP traffic as its so rare, but i just need it to work (forward to 1 server perhaps)
