Hi friends,
I have a communication problem between Zabbix Proxy and Zabbix Server at port 10051. I’m using HAPROXY version 2.0.13. Look my Kubernetes scenario:
HAPROXY is working fine when I access my website zabbix.domain.com at port 80 and 443.
Zabbix-Proxy has a parameter “Server” that I set with ip address of worker-1 and the communication works fine, but this happen because the traffic don’t pass through HAPROXY server. When I try to set the Server parameter with my domain address zabbix.domain.com that go to my HAPROXY server, the communication dont work, give the impression that HAPROXY cant treat the request.
zabbix_proxy.conf: Work with Worker-1 ip addr, but dont work with domain name.
The domain name as I said, is pointing to HAPROXY server (10.0.0.110). I think the zabbix-proxy is trying to reach the port 10051 of HAPROXY server and the HAPROXY can’t deal with the requests to forward to my worker node.
This is my HAPROXY configuration, I test with frontend and backend, but now, I just rewrite with Listen parameter.
listen zabbix
bind :10051
server worker-1 10.10.10.112:10051 check
server worker-1 10.10.10.113:10051 check
server worker-1 10.10.10.114:10051 check
frontend http_front
default_backend http_back
frontend https_front
bind *:443
default_backend https_back
frontend kubernetes
bind *:6443
default_backend kubernetes-master-nodes
bind :9000
stats hide-version
stats uri /haproxy_stats
stats auth admin:admin
option tcp-check
server master-0 10.10.10.111:6443 check fall 3 rise 2
backend http_back
option tcp-check
option log-health-checks
default-server inter 10s fall 2
server worker-0 10.10.10.112:80 send-proxy check
server worker-1 10.10.10.113:80 send-proxy check
server worker-2 10.10.10.114:80 send-proxy check
backend https_back
option tcp-check
server worker-0 10.10.10.112:443 send-proxy check
server worker-1 10.10.10.113:443 send-proxy check
server worker-2 10.10.10.114:443 send-proxy check
Someone can help? There are some manner to point to my website zabbix.domain.com, the haproxy treat the request send to my worker-1 in port 10051? Please tell me If need more information.
