Haproxy load testing on h2 responce with NOSRV after 6000 hit/s
HI,
i dont know if the error comming from my config, can anyone help
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-GH4GHa/haproxy-2.0.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with multi-threading support (MAX_THREADS=64, default=16).
Built with OpenSSL version : OpenSSL 1.1.1c  28 May 2019
Running on OpenSSL version : OpenSSL 1.1.1d  10 Sep 2019
Built with PCRE2 version : 10.32 2018-09-10
Available services :
	prometheus-exporter
config
	log /dev/log	local0
	log /dev/log	local1 notice
        tune.h2.max-concurrent-streams 100000
    	tune.maxaccept -1
    	maxconn 2000000
    	nbproc 1
    	nbthread 8
    	cpu-map auto:1/1-8 0-7
        tune.ssl.cachesize 1000000
        ssl-default-bind-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-RSA-DES-CBC3-SHA:ECDHE-ECDSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:DES-CBC3-SHA:HIGH:SEED:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!RSAPSK:!aDH:!aECDH:!EDH-DSS-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!SRP
        ssl-default-bind-options no-sslv3  no-tls-tickets
	log	global
	mode	http
	option	httplog
	option	dontlognull
        timeout client  50000
        timeout server  50000
	maxconn 200000
frontend public
    bind :443 ssl crt /etc/ssl/private/perfheck.crt alpn h2,http/1.1
    default_backend perfheck
    maxconn 200000
backend perfheck
  maxconn 200000
  server srv01  10.23.66.16:443 ssl verify none
  server srv02  10.23.66.8:443  ssl verify none
  server srv03  10.23.66.5:443  ssl verify none
  server srv04  10.23.66.6:443  ssl verify none
  server srv05  10.23.66.7:443  ssl verify none
  server srv06  10.23.66.15:443 ssl verify none
logs
Oct 30 18:27:43 server haproxy[25002]: 127.0.0.1:54793 [30/Oct/2019:18:27:10.353] public~ perfheck./<NOSRV> -1/-1/32673 0 CR 2/2/96/0/3 0/0
Oct 30 18:27:43 server haproxy[25002]: 127.0.0.1:54793 [30/Oct/2019:18:27:10.353] public~ perfheck.<NOSRV> -1/-1/32673 0 CR 2/2/95/0/3 0/0
Oct 30 18:27:43 server haproxy[25002]: 127.0.0.1:54793 [30/Oct/2019:18:27:10.353] public~ perfheck./<NOSRV> -1/-1/32673 0 CR 2/2/94/0/3 0/0
after some changes in backend and haproxy config i am able to reach 35 000 hit/s, but when going for more than that i see the NOSRV error i’m using a debian 10 with 16 cpu 14g
