On a production server the memory usage of HAProxy has reached 75.7% out of 8 GB and the usage is growing as time passes by, so I have the feeling that we might have memory leak somewhere. We use HAProxy 2.5, any tips on how to fix/diagnose the problem is much appreciated.
The number 1 reason is maxconn values incompatible with your RAM situation, often combined with too large timeouts.
So maxconn and timeout values are the first thing to look at.
The other reason can be tune. values that are set too large.
I guess you could cause large memory consumption with bugs in LUA scripts too. Compression, caching and other filters may also contribute to excessive memory consumption.
The output of haproxy -vv and the configuration would help here, however 2.5 is unsupported at this point. But I’m not aware of any memory leaks in the last decade to be honest, so I doubt this is an actual bug in haproxy.
Hello @lukastribus thanks for your time.
these are our timeout and maxconn values
maxconn 60000
timeout connect 5000ms
timeout client 50000ms
timeout server 3000ms
timeout tunnel 1h
and here is haproxy -vv output
HAProxy version 2.5.10 2022/12/05 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2023.
Known bugs: http://www.haproxy.org/bugs/bugs-2.5.10.html
Running on: Linux 5.10.0-23-cloud-amd64 #1 SMP Debian 5.10.179-2 (2023-07-14) x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_TFO=1 USE_PROMEX=1
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL +THREAD +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
Running on OpenSSL version : OpenSSL 1.1.1n 15 Mar 2022
Built with PCRE2 version : 10.32 2018-09-10
Built with gcc compiler version 8.3.0
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
[FCGI] fcgi-app
I am sharing this info here for you to have a closer look on the problem we are facing,
We saw that our fresh copy of haproxy image started from almost 130MB, but in few days when almost 80 backends were created dynamically, with each has 100 servers, haproxy memory usage was increased to almost 6GB, although it increased gradually in 10 - 13 days to this level.
I will take little time to think about your suggestion regarding lua script. And will update
Not sure anymore, there are quite some LUA related leaks in there:
You should probably work on upgrading to a supported branch with the latest bugfix release as per haproxy.org
