Haproxy newbie.. udp solution
hi guys,
I’ve got haproxy working fine with vrrp doing ssl passthrough for a couple of gateways but it only occurred to me after i set them up that it doesn’t support udp
where should I be looking to offer ssl & udp for windows rd gateways?
many thanks.
You can use LVS, which is included in your kernel.
