Hi guys,
We use HaProxy to manage our applications access to the microservices.
We are talking about some 21 microservices, which extend to 63 virtual machines and 63 ACLs
What we have noticed tho is that from time to time, it self-reload itself.
We have been having some issues where Rundeck jobs will crash due to timeout, HaProxy might be the culprit.
The timeouts don’t match the ones in place. It is like it just happens from nowhere.
We have another HaProxy, the same stable version, 1.8.14-52e4d43, running MariaDB. It has been running fine for months without any self-reload.
The only difference is that the database one uses TCP while the microservices one is using HTTP/HTTPS.
The image below is part of a long static page. Observe the status
I don’t know what could be possible causing this.
I am sharing part of the config file showing the common places to have problems.
I appreciate any help.
timeout http-request 10s
timeout queue 1m
timeout client 15m
timeout server 15m
timeout http-keep-alive 10s
timeout check 10s
maxconn 4000
frontend http
acl SOMETHING_IP src IP
A dozen ACLs like above
acl SOMETHING_SERVICE path_reg ^/SERVICE
use_backend SOMETHING_SERVICE if SOMETHING_IP SOMETHING_SERVICE
Dozens ACLs like above
option httpchk OPTIONS * HTTP/1.1\r\nHost:\ www
server SOMETHING_IP SOMETHING_IP:80 weight 10 check port 80 inter 1s fall 1 rise 3
server SOMETHING_IP SOMETHING_IP:80 weight 0 check port 80 inter 1s fall 1 rise 3
Thanks guys
