Hello, I am using nginx rtmp on my server for streaming. I have 1gbps server but itis not sufficient. I have 2nd server with 1gbps. I want to add 2nd server as a haproxy load balancer so that my stream will get 2gbps. I want to add more servers like that. What will be the procedure to add? Installation methods are available on internet but I don’t know which setup should I use so that my stream will get another 1gbps from 2nd server. Also I want to use cpu of 2nd server. It will increase stability of streaming. Please help me to setup.
Thank you in advance.
No one hepls here?
This is a complex topic, I do not imagine that you will get all the answers you need in this forum, but generally speaking you will have to put haproxy on a third server connected with 10Gbit/s and then load-balance in tcp mode towards the two existing servers.
Can you please provide me any perfect tutorial to setup tcp load balancer?
anyone please provide me any perfect tutorial to setup tcp load balancer?
