I observe SSL Handshake failures in my Haproxy logs. Sometimes this occurs when the web application is trying to save data or is receiving a larger post and it causes the web application to throw an error also.
Environment notes: We are running RHEL 7 - Using Haproxy to interface two active webbackends servers and one backup webbackend servers We are using Cherrypy for the web application.
Here is an example error in the cherrypy logs:
server02 [4.xxx] [INF] (web/services/web/site-packages/cherrypy/_cplogging.py) 10.111.233.123 - - "GET /~api/entity/tMatch%22%3Atrue%7D%5D HTTP/1.1" 200 41 "https://www.example.com/" "Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Firefox/78.0"
File "/web/services/web/site-packages/OpenSSL/SSL.py", line 1545, in _raise_ssl_error
raise ZeroReturnError()
File "/web/services/web/site-packages/OpenSSL/SSL.py", line 1734, in recv_into
self._raise_ssl_error(self._ssl, result)
OpenSSL.SSL.ZeroReturnError
And here is the corresponding entry in haproxy:
Apr 26 13:27:38 localhost haproxy[2487]: 192.200.5.43:50600 [26/Apr/2021:13:27:38.136] www.example.com:80/2: SSL handshake failure
Here is the Haproxy build info:
HA-Proxy version 2.0.14 2020/04/02 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_THREAD=1 USE_LIBCRYPT=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
Here is my Haproxy Configuration file:
# Global settings
# need to:
# by adding the '-r' option to the SYSLOGD_OPTIONS in
# /etc/sysconfig/syslog
log 127.0.0.1 local2 info
pidfile /var/run/haproxy.pid
maxconn 4000
ssl-server-verify required
# turn on stats unix socket
stats socket /var/run/haproxy/info.sock mode 660 level user user report group zabbix
stats timeout 2m # Wait up to 2 minutes for input
timeout http-request 10s
timeout queue 1m
timeout client 5m
timeout server 5m
timeout http-keep-alive 10s
timeout check 10s
maxconn 300
frontend example.com:80
bind *:443 ssl crt /etc/ssl/certs/web.pem
http-request set-header Forwarded for=%[src]
default_backend web_servers
# round robin balancing between the various backends
backend web_servers
option httpchk GET /#
cookie SERVERUSED insert indirect nocache
redirect prefix https://www.example.com code 301 if { hdr(host) -i old.example.com }
#List all the web servers below
timeout queue 10s
server backendweb1 10.111.233.122:8443 check ssl verify required ca-file /etc/ssl/certs/web.pem cookie web1
server backendweb2 10.111.233.123:8443 check ssl verify required ca-file /etc/ssl/certs/web.pem cookie web2
server backendweb3 10.170.218.123:8443 check ssl verify required ca-file /etc/ssl/certs/web.pem cookie web3 backup
listen stats # Define a listen section called "stats"
bind :::8404 v4v6 ssl crt /etc/ssl/certs/web.pem # Listen on localhost 8404
stats enable # Enable stats page
stats realm Haproxy\ Statistics # Title text for popup window
stats uri /stats # Stats URI
stats refresh 10s
stats auth xxxxx:xxxxxxxxxxx #Authentication credential
stats admin if LOCALHOST
