I wanted to have 2 backends, each responding to an acl with different host name. It appears tcp mode is non able to distinguish this property from the connection, because I managed to connect both backend with a different acl, by dest_port. So http is the way right? Ok, got my .pem and added to the config, and since then…
I tried reverting to the previous working config but my haproxy server is not responding anymore
Every attempt shows same log, 4 per attempt
tail /var/log/haproxy.log
httplb/ -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 “”
Is there any issue editing the ubuntu haproxy.cfg from windows with vscode sshfs?
It appears some lines are not marked correctly when saved from Windows, especially carriage return. Anyway for this issue I also tried converting the file with dos2unix…
