Hi HAProxy community
Im trying to configure traffic mirroring from prod haproxy to stage haproxy instance for testing purpose
thanks to the article https://www.haproxy.com/blog/haproxy-traffic-mirroring-for-real-world-testing mirroring works, but i’m not able to transfer real client ip to target test haproxy instance
the source IP in access log is always IP of prod haproxy with spoe agent. The application behind haproxy require client ip headers.
Is there way to pass X-Forwarded-For or X-Real-IP header in the spoe engine mirror config?
haproxy.conf
master-worker
ulimit-n 3100000
maxconn 100000
maxconn 100000
option dontlog-normal
retries 5
timeout connect 1s
timeout client 5s
timeout server 10s
timeout client-fin 500ms
timeout server-fin 500ms
timeout http-request 10s
timeout http-keep-alive 300s
program mirror
command spoa-mirror --runtime 0 --mirror-url http://<domain-name>
frontend http
filter spoe engine mirror config /etc/haproxy/mirror.conf
default_backend nodes
backend nodes
option httpchk HEAD / HTTP/1.1rnHost:localhost
server host <ip>:<port>
backend mirroragents
timeout server 5s
server agent1 localhost:12345
mirror.conf
[mirror]
spoe-agent mirror
messages mirror
use-backend mirroragents
timeout hello 500ms
timeout idle 5s
timeout processing 5s
spoe-message mirror
args arg_method=method arg_path=url arg_ver=req.ver arg_hdrs=req.hdrs_bin arg_body=req.body
event on-frontend-http-request
