Hi. I need to enable traffic mirroring from the production server to staging. We had this working in the past, but I’m unable to restore the setup, probably because of technical changes that happened in the meantime.
In the normal workflow, we do TLS termination in HAProxy and forward in plain HTTP to backend servers. I believe I’m not managing TLS correctly at SPOE level, but I cannot find what’s wrong.
I forward spoa-mirror traffic back in HAProxy again to alter the Host and Location headers, replacing production hosts with staging ones.
master-worker
mworker-max-reloads 3
set-dumpable
log 127.0.0.1 local0 info
log 127.0.0.1 local1 notice
maxconn 25000
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM
ssl-default-bind-curves X25519:secp521r1:secp384r1:prime256v1
option dontlognullmonitor probes)
option log-separate-errors
timeout connect 20s
timeout client 100s
timeout server 100s
timeout http-keep-alive 80s
frontend web
bind *:443 ssl crt /etc/haproxy/certs/ alpn h2,http/1.1
http-request del-header Proxy
http-response add-header X-Frame-Options DENY
filter spoe engine mirror config /etc/haproxy/mirror.cfg
program mirror
command /usr/local/bin/spoa-mirror --runtime 0 --mirror-url "http://127.0.0.1:9000" --logfile A:/var/log/haproxy-mirror.log
# We receive back SPOA's traffic and alter headers
frontend spoa_frontend
bind *:9000
http-request replace-value Location ^my.domain.es(.*) staging.my.domain.es\1
http-request add-header X-Is-Mirrored yes
use_backend spoa_backend
# SPOA destination
backend mirroragents
timeout server 1m
server agent1 127.0.0.1:12345
# Backend server where the SPOA mirrored traffic is delivered
http-request set-header Host staging.my.domain.es
http-request replace-value Location ^https://my.domain.es(.*)$ http://staging.my.domain.es\1
server stagingsrv stagingsrv:80 check inter 2000 rise 2 fall 3
And this is mirror.cfg
[mirror]
spoe-agent mirror
messages mirror
timeout hello 500ms
timeout idle 10s
timeout processing 100ms
use-backend mirroragents
spoe-message mirror
args arg_method=method arg_path=url arg_ver=req.ver arg_hdrs=req.hdrs_bin arg_body=req.body
acl is_prod hdr(host) -m str my.domain.es
event on-frontend-http-request if is_prod
This is the log of a request performed with curl:
==> haproxy-mirror.log <==
[ 7][ 9366.125010] "GET http://127.0.0.1:9000https://my.domain.es/ HTTP/???" 0 0/0 0.000
==> haproxy-http.log <==
Feb 28 14:29:26 localhost haproxy[376208]: SPOE: [mirror] <EVENT:on-frontend-http-request> sid=40796 st=0 0/1/0/0/2 1/1 0/0 0/10
Feb 28 14:29:27 localhost haproxy[376208]: 15.24.10.11:60855 [28/Feb/2024:14:29:26.783] web~ backend_http_cluster/spain-01 2/0/1/549/567 200 14425 - - --NI 1/1/0/0/0 0/0 "GET https://my.domain.es/ HTTP/2.0"
I’m puzzled by the HTTP/??? output of spoa-mirror, that I found in curl.c for CURL_HTTP_VERSION_NONE.
Anyway, in the logs we never get a record for the spoa_frontend, that means the mirror agent is never forwarding the request there. But I haven’t found a verbose option for spoa-mirror…
thanks
